Thread: EMS for a turbo built 6g72
Showing results 1 to 20 of 25
    Member
    05-25-2009
    Around the corner
    122
    Hey guys, Im fairly new to the world of FI. I just purchased a turbo set up for my gtz with a t3/t4 hybrid turbo and also my motor is some what built with CP Forged 8:8:1 Pistons, Shot Peened Rods, Overbored .40, and Rpw valve springs. Now I have to figure out what EMS system to go with. My question is what systems are some of you FI guys using, pros/cons? and what would you suggest? Im currently looking at the emanage ultimate just because I can get it for about 500 new from a friend. let me know! any infor or insight would greatly be appreciated. Also im mainly going to be using this car for just weekend fun/driving and track it every once in awhile if that matters. Thanks!
    10-05-2008
    Grand Rapids Michigan
    1,141
    How about pics !!!!
    Member
    05-25-2009
    Around the corner
    122
    also im looking into running coil packs also because ive read the our distributers wont last long on a boosted set up. any insight on that would be great also. thanks!
    johnygezony- ill try to get you some pics tonight or tomorrow.
    12-02-2008
    Carteret & Manalapan, NJ
    1,263
    Well my question to you is why are you running on stiffer springs on stock camshaft, and what turbo kit did you get....there are no turbo kits out for our cars but the ebay kits which are a majoy nono unless you dont care spending money on fixing the damages. Give us pix and more info about what you have and maybe we can help...
    Member
    05-25-2009
    Around the corner
    122
    ... i dont even think there are ebay turbo kits for our cars or even the v6's. But the kit i purcahsed was a custom kit made by turbo concepts in michigan. its uses the turbo concepts wastegate, precision t3/t4 hybrid turbo, turboxs blow off valve type H.
    12-02-2008
    1,263
    http://cgi.ebay.com/ebaymotors/JDMS-...item1c0b8e2869
    Yes they do.lol but hey as far with EMS Im not sur ewhat people out there use for the v6 models. The ultimate E-mag sytem should do fine unless other people have other thoughts, but that might be your best bet. Im still on the question on asking you is why did you upgrade the valve springs with out running a more agressive cam?
    Member
    05-25-2009
    Around the corner
    122
    haha wtf i guess you can find / get anything on ebay. lol. as far as the valve springs go those were installed by the shop that built the motor for the previous owner. so its a good question. ill have to give him a call and ask
    04-02-2009
    Denver Colorado
    1,447
    How much power do you plan to make, how much pis of boost are you going to run? Any fuel upgrades (injectors, pump, Adjustable FPR?)
    The E-manage Ultimate will do just fine for the boost build whether its the V6 or 4cyl engine. The benefit really for the Ultimate is that you can ditch the MAF sensor as well. The distributor should be good up to I think 300-350hp or more, but don't hold me to that exact number just yet as I will have to dig through some of the old information I have stuffed away at home.
    If they put stronger springs in the motor on stock cams, it is possible they were building the motor for a mid-high end RPM power powerband so the valves will close quicker and helps to reduce valve float in those RPM ranges. You would likely not notice much of a gain from doing this on stock cams, but it is more common on aftermarket cams.
    Also the T3/T4 Hybrid turbo choice is "ok" to start with, but I would guess you will quickly need to upgrade to something different unless you don't plan to run very much boost, or bigger HP numbers.
    www.blackheartmotors.net
    10-05-2008
    1,141
    where in michigan is turbo concepts ? I live in GR
    oh and that so called "kit" is just a universal set up, there is no manifold
    Member
    05-25-2009
    Around the corner
    122
    Hey thanks for the responce! I did pick up a fuellab fpr and I am also going to be getting a walbro fuel pump and injectors but im still doing some homework on what i should get. So if you have any insight that would be great! Sorry im a noob at this =). Im still trying to get as much info on what parts and things I should be getting. Rather ask questions and be safe rather then blowing my shit up haha. As far as hp goes Id like to break into the mid 300s and then as I learn more I would want to try and break 400. From what I was told I need to upgrade the distributer because thats what went bad on the motor. It was suggested I do coil packs. Thanks for the info!
    Member
    05-25-2009
    Around the corner
    122
    Quote Originally Posted by johnygezony View Post
    They are located in Brighton
    10-05-2008
    1,141
    ^ok so by ann arbor
    Member
    05-25-2009
    Around the corner
    122
    Heres a quick cell phone pic
    What sized injectors bro?
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
    is the car blue?
    Jigz-TGCIL Sosick Motorsports
    Member
    05-25-2009
    Around the corner
    122
    no my car is black with the custom faded clear coat look haha
    11-05-2003
    San Francisco Bay Area
    1,517
    I was running the older eManage Blue, so I am sure the eManage Ultimate should be fine. I didn't have any problems with the distributor, but I didn't push my car either, as I was still running a stock block with 7.5psi at the most.
    08-04-2003
    NY
    4,344
    OMG that oxygen sensor is REALLY close to the turbo, your gonna be buying o2 sensors every 5,000 miles.
    99' Galant ES
    4G64/63T
    AEM EMS
    04-10-2005
    NYC
    3,695
    generally for the v6 if you want a standalone, go with the haltech. as of this moment as far as im aware the ems is not compatable with our cars per say. you are able to go with a universal however that can get quite expensive. there is however last time i checked a member who is trying to create a setup for our cars.
    of course a standalone is always better but the e-manage is also a good alternative. while you wont be able to achieve everything you would from a standalone it is the next closest thing
    I sell a plug and play kit for an AEM EMS for the V6 5 spds. Yes I can build a harness for the auto's too, but the stock computer has to stay in the loop to drive the auto.
    Greg
    '01 Stratus R/T - 5spd, 92 3000GT VR4, 03 EVO VIII, 70 Opel GT
    Owner - Ultimate Car Style & Performance www.ucsperformance.com 240.271.0280
    2007 N.A.S.A National Champions TTR Class!
