Thread: An easy question about my wheels - pic
Page 2 of 2 FirstFirst 12
Showing results 21 to 25 of 25
    Quote Originally Posted by Serstylz2 View Post
    tire pressure should be listed on the tire itself..
    Nope. This is a very common misconception.
    The pressure on the tire is the maximum pressure the tire can hold at normal operating temperatures during an extended period of time.
    I run my tires at 36 in the front, 33 in the rear.
    09-10-2003
    Charlotte, NC
    4,463
    wow did that know that info. thanks folks
    04-29-2009
    Holyoke,Massachusettes
    3,600
    im looking for those wheels myself. no luck though.
    FreakyDeaky
    2kG 6g72/74 5 speed
    05-02-2008
    Hacienda Heights, CA
    3,014
    i just got those too lol
    There a lot a good information here. We certainly have a lot of misconceptions, and I am glad we can clear some out.
    I was told that more air than spec, by 5-7 PSI more = fuel savings, with some minor compromising of safety/grip.
    Stock numbers are indeed 32 front, 29 back, (as mentioned before by others) just because the front holds more weight and needs extra pressure on braking.
    I'm gonna do 37F/34R I think.
    I've got the Yokohama YK520 right now,
    225/45R17 91H Part No. 31729
    max load @ pressure 1356@51
    So 37 PSI sounds pretty OK.
