Thread: springs
Showing results 1 to 3 of 3
    rizzla
    springs
    anybody know if all eclipse 1g nt springs fit on 6g galant 2.0 nt
    and if the galant 6g sohc springs are the same as the galant dohc nt
    I would also like to know if the front strut bar from eclipse fit on galant 6g
    thanks
    Rasko Da Gama
    I'd like to know that too... Anybody?
    "Proud Galant Driver" do you know? :?:
    ken inn
    on a vr4, the t/e/l strut bar will fit if you turn the mounting brackets around 180 deg. but, i dont know if it will clear the intake. on a vr4, which i suspect is very similar to the other galants, the spring perches on the front struts are a tad(about 1/2") taller than on the gsx. the springs on the gsx are rated higher than the vr4, and are slightly shorter. overall length of the front strut of the galant is also longer. dampening is about 30% more on the gsx. on the rear of the vr4, the difference is about 2", the galant is longer. spring rates and dampening are also very different. the springs and struts will bolt up, but you may have issues on height and ride. it is better than nothing, tho.
