Thread: 7G Suspension help
Showing results 1 to 13 of 13
    7G Suspension help
    I know the 2g setups for suspension fit the 7g, is there and thing that needs to be done or is it just a direct bolt on? found a set I like and want to know before I waste any money. found a good price, if anyone has any info in these, like they suck or something then let me know.
    http://www.autopartswarehouse.com/sk...n+%26+Steering
    every eclipse to date... has been drafted from the previous year galant chassis.
    89 6g galant: '90 1g eclipse
    94 7g galant: '95 2g eclipse
    99 8g galant: '00 3g eclipse
    04 9g galant: '06 4g eclipse
    Every eclipse is drafted from a galant chassis.
    so all of your suspension parts will swap over from the respective generations of eclipse:galant as well as galant:eclipse.
    So to answer your question, if it is for the 2g eclipse suspension, it will in fact fit your car with no extra modification
    sweet thanks. I would also assume that the trims make no difference then. IE 2G GSX to galant
    no real difference. only thing in that situation that would matter is the rear wheel bearing would be different in the sense that its designed to accept an axle. but it would still work(provided you wanted to go 5 lug)
    some trims have better specs.
    You can use a gsx sway bar, but it has different bends to it. It will work fine with your stock everything, but say you went with a beefy 3" exhaust you may run into problems with the exhaust hitting the swaybar.
    So to make things simpler, just get parts for the 2g fwd
    I think MKO found a way around the gsx sway...8G 18mm sway... and this is entirely off subject but where did you get your rims?
    08-13-2008
    Waterbury, CT
    3,331
    i had tokico illuminas with those springs
    the hps are ok
    http://cgi.ebay.com/ebaymotors/TOKIC...Q5fAccessories
    that is exactly what i bought from the exact same vendor.. smae springs as the 1s u looked at, but these shocks are adjustable stiffness and awesome
    heres how it sat when i had my tokicos on
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    ^ needs more spacers
    08-13-2008
    Waterbury, CT
    3,331
    it did.. i sold the setup recently john and im back to stock height until i get coilovers
    2014 Lancer Evo GSR
    ya and I would have totally jumped on those to.... but stupid me I just went out and spent way to much on an engagement ring.... I should have bought the suspension set up and some new wheels and tires for the price I got shafted out of...lol
    You've made a wise decision. D2 I pray?
    08-13-2008
    Waterbury, CT
    3,331
    you bet john.. they are on the 240 and i love them so they are going on the galant prolly next year.. until then ill get the motor all set and some minor body work then paint and coilovers
    2014 Lancer Evo GSR
    I like the look of the drop GT10, needs like 1/2 inch wheel spacers but still looks sweet
    08-13-2008
    Waterbury, CT
    3,331
    Quote Originally Posted by RedLine DOHC View Post
    thanks man thats with the tokicos.. i sold that recently and im on stock height til coilovers.. and with all the strut bars and the rear sway upgrade im very happy with it.. cant wait for those D2s
    2014 Lancer Evo GSR
