Thread: AMP - SUB Issue.
Page 1 of 3 123 LastLast
Showing results 1 to 20 of 44
    AMP - SUB Issue.
    Alright, kinda disappointed/or i'm an idiot.
    I'll start with my disappointment. I just replaced my 300W Bridgeable Kenwood KAC-608S with a 600W MONO Class D Kenwood KAC-6104D.
    It isn't hitting NEARLY as hard as the older 300W model.
    What did I screw up?
    72,500 miles as of 3/30/11
    how do you have the speakers wired up? series, parallel? is it single or dual voice coil sub? how many subs?
    if its a class d amp it only has one channel right?
    General Features
    • Max Power: 600W
    • Class D Mono Power Amplifier
    • 2Ω Load Capability
    • Power MOS-FET Switching Power Supply
    • Cast Aluminum Heat Sink
    • Built-In Low-Pass Filter
    • Speaker-Level Inputs For Easy Factory Integration With Factory Stereo
    • CEA-2006 Compliant
    • 1-Year Warranty
    Specifications
    RATED OUTPUT POWER (14.4V):
    • 200W RMS x 1 @ 4Ω
    • (20Hz-200Hz @ 1%THD)
    • 300W RMS x 1 @ 2Ω
    • (100Hz @ 1% THD)
    RMS POWER OUTPUT (CEA-2006)
    • 200W RMS x 1
    • (RMS @ 4Ω, 1% THD+N)
    • 75dBa Signal-To-Noise Ratio
    BUILT-IN CROSSOVER CONTROL:
    • Variable Low-Pass Filter: 50Hz-200Hz (12dB/oct)
    • Operating Voltage: 14.4V
    • Current Consumption: 21A
    • S/N Ratio: 94dB
    • Frequency Response: 20Hz-200kHz
    • Input Sensitivity: 0.2V ~ 5.0V
    Installation Size:
    • Width: 7-13/16” (198mm)
    • Height: 2-5/16” (59mm)
    • Depth: 9-1/16” (230mm)
    • Weight: 4.0lbs. (1.8kg)
    - David
    and i thought most class d amps were 1 channel lol
    IF you just replaced the Amp w/ this, I'm guessing you haven't screwed around w/ any wiring anywhere else.
    Play w/ the Amp settings... Up the Gain or something... Remember, when you have a Amp bridged it does produce more a thump.
    Check your HU (head unit) EQ and Amp settings as well....
    - David
    hold on while i show how i connected the sub to the amp.
    4GA Power and Ground
    REMOTE from back of HU
    LINE IN RCA from from HU
    GROUND TO TRUNK
    I'm the one who originally installed/wired the system, so i'm pretty sure it's correct. I've just never used a MONO amp before.
    you sure that's not a 2 channel, my mono only has 2 sub outs,(pos-neg) cause if that's a 2 channel I don't think its bridgeable usually it indicates on the amp where to bridge.
    of try moving the pos terminal to the other empty terminal...etc.. try moving those around.
    I checked the manual before installing it like a bridge, it showed if only one sub to set it up like that.
    UPDATE:
    Opened the sub to see if it is the dual or single voice coil model of the MTX Thunder 5500.
    It's the single voice coil at 4ohm.
    - It seem's to be "cleaner" bass than the old 99' Kenwood.
    I have the input sensitivity cranked, and LPF at around 115Hz
    its only 4 ohm so your only getting 200 watts. that might be why it isnt that loud
    also make sure its bridged
    littlerick, my 300W Bridgeable Kenwood KAC-608S was only 150RMS when bridged, so the new amp should be louder at 200RMS.
    It can't be bridged since it's a mono AMP, it only has 4 outputs since it can either be used by dual or single voice coil.
    04-19-2008
    Texas, Houston
    450
    Your newer amp KAC-6104D is not bridgable, its a mono amp that can handle two single subs. So its kinda like a dual mono amp. Your older amp has a 300 max with 150rms brigde so im guessing 100 single. So your setup right now from the picture only pushing out 100rms which is of course lower then 150 and why it isnt bumping more like you want. at 4ohm you get about 200rms if you properly connect it. I do need to know the size of your sub cause mtx 5500 makes 4 diff sizes and diff rms etc. Ill explain more when i get this info
    01-10-2008
    Oceanside/Camp Pendleton, CA
    1,848
    Quote Originally Posted by littlerick View Post
    mono means 1 you idiot. but there are class d 2 and 5 channels as well
    where did i say mono didnt mean 1? all the class d amps i've ever messed with were 1 channel. thats the first mono amp that i've seen that has a place for 2 speakers.
    01-10-2008
    1,848
    i see them all the time. the reason why you usually only see class D as mono is because they are very efficient on power but not high on sound quality. Class A is just the opposite.
    Yeah I thought it was odd how they show in the manual that you can hook up TWO subs to this MONO amp.
    How weird.
