Thread: Huge Problem
Showing results 1 to 12 of 12
    7gloverhater
    Huge Problem
    I have a problem my only car and i took a 96 and put the engine just the engine in a 95...just the engine and now the engine wont flush up with the trany SOHC auto trans nothinig moddifyed just plane jane what do i do ???
    11-14-2007
    Boothwyn,PA
    719
    It should flush up.. Maybe you have it at a weird angle. Also make sure that your torch converter is in all the way and lined up on the splines that might be why its not going on right... Whatever you do dont force it because that ois when you screw somthing up....
    7gloverhater
    Quote Originally Posted by skrap View Post
    no we didnt force it but the thing is the front guide pin is lined up and goes in but the back pin doesnent.... the 95 has DSM tags and my old 96 has Mitsu tags i am putting the 96 e=ngine in the 95 car with the 95 tranny
    08-13-2008
    Waterbury, CT
    3,331
    dsm tags dont matter as they were all made at the same plant and the dsm tags stopped going on cars after 95 including the eclipses and talons
    they all have the same model tranny as well.. if something isnt lining up id check more than just what your trying to make fit cuz one misalignment always causes trouble
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    Bronx NYC (reppin)
    3,489
    all trans from 94-98 should fit.
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
    ah i forget the name of these things, but they are sit either in the tranny or the block. they look like small cylinders and you push the tranny bolts thru. sometimes they are stuck to the tranny sometimes they are stuck to the block. if you have one of them on the tranny and one the block for the same hole then it wont be flush. i caught one like that when i was switching trannies back in the day
    Bronx NYC (reppin)
    3,489
    dowel pins
    7gloverhater
    we got it in after too long an not the idle is bouncing real bad not shure what to do
    Tps + sas + biss
    Bronx NYC (reppin)
    3,489
    ya what he said.
    7gloverhater
    what is the sas and biss i knwo the tps is throtle possition sensor??
    7gloverhater
    anyone know??? the sas? tps??
