jack your car up and check for play in the wheel. if your bearings are fine, and you still have play, your ball joints could be worn even if the boots are fine.
check every ball joint. Your tie rods are only a start. However, I can assure you that if your tie rods are original, they need to be replaced. Both inner and outer.
