Thread: Eibach front only
Showing results 1 to 2 of 2
    wmaharrisjr
    Eibach front only
    Is anyone running the Eibachs fronts only with their KYB's and stock in the rear? I don;t like how my car is sitting with both the front and rear dropped. my rear looks even lower because I have a heavy system in the trunk so now it drags even more since its been lowered and makes the car look uneven. I want the front to be a lil lower than the back to give it a sporty look. Also what performance effects would there be if i were to run Eibachs in the front and stock in the back. Well it help any to upgrade the rear sway bar
    PLEASE POST PIC OF PEOPLE WITH THE APPLICATION
    Thanks for your help
    nsg123
    Eibachs
    The Eibach sportlines, with the 2 inch drop, do they or will they fit a i4, becasue they are listed to fit a V6, i was wondering if you would know?
