Thread: How to rewire the ISC for 60mm TB
Showing results 1 to 10 of 10
    1g/94GS ISC
    1g ISC plug colors may differ, but the pinout is the same.
    94-98 7g SOHC/ 95-99 Eclipse Spyder
    Spyder ISC plug colors may differ, but the pinout is the same.
    1g/94GS pins.......-.......7gSOHC/Spyder pins
    .......1..................................5....... ...
    .......2..................................1....... ...
    .......3..................................6....... ...
    .......4..................................2....... ...
    .......5..................................1....... ...
    .......6..................................4....... ...
    There's a pin left on the 7gSOHC/Spyder plug. That's the ground pin-3. 1g Style ISC does not use ground - it uses two +12V and that's why pin 1 on 7g/Spyder plug needs to be spliced into two for pins 2 and 5 of 1g/94GS plug.
    I been thinking about it but i didn't know if it would work the way i was thinking.
    can we use it on stock setting?
    by mean stock manifold, intake tube..etc
    you could but it wont have any effect if the manifold istn ported
    You would see some gains with the im unported I have mine unported and the 68mm tb on mine
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
    I though 6g74 has a 65mm TB
    But do port it. It makes all the difference in the world
    Blackheart measured with calipers and said it was 68mm but yeah I will port the im when I get the chance
    08-13-2008
    Waterbury, CT
    3,331
    For people doing the DOHC swap or going turbo and not wanting to port the mani this also works for a 2G TB and IAC as they use the same IAC.
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    I grabbed a turbo TB from a 1991 talon TSi the wires are 1-6 in the order of your illustration
    1-blue
    2-red
    3-yellow
    4-black
    5-red
    6-white
    Iirc black is always ground but it does have the two red wires you mentioned bit no green and instead of a white at 4 its at 6 and the black is at 4
    Any input
    Me I'm a lil of both
    Bump
