Thread: Take alook at my manual transmission, need opinions
Showing results 1 to 17 of 17
    05-24-2005
    Greensboro, NC
    494
    Went to look at 5-Speed transmission today, it came from a 2001 GS. I got transmission, pedals, clutch lines, shifter and cables for $100. Yeah I know $100 is cheap and that because it seem the flywheel cut into the bell housing somehow. Here are some pictures of the transmission. The cut goes all the way around the bell housing, except around the starter. I need input on what could case this and what other damage can occur internally to the transmission.
    v6 manny? doesnt look like my i4. i dont think it could of done any more damage seeing that there wouldnt be any place for the flywheel to go but where it made its cut marks. im thinking the flywheel bolts just snapped or something alone those lines good luck.
    pretty good price :) my full 5 speed swap is under 300 hundred and i only need flywheel bolts, tob and a speed sensor. i would make sure all the gears engage and the axel housing gears moves when you turn the center shaft .
    looks to round to be broken parts.... looks more like over sized flywheel or possibly part of the pressure plate.
    05-24-2005
    Greensboro, NC
    494
    The flywheel/clutch/pressure were still attached to the engine and the transmission was already out the car. I just couldn't pass on the deal. The transmission is for a I4, I can turn the shaft but not sure about the gears.
    move the gear lever. see if it goes into every gear.
    Looks like you just need to find someone who can weld the bellhousing you have now, or just get a new bell housing.
    Make sure there is no play in the shaft either. no up/down and especially no left/right
    looks like you are missing the cover thats on the shaft...
    Jigz-TGCIL Sosick Motorsports
    Bronx NYC (reppin)
    3,489
    Quote Originally Posted by Exhaust power View Post
    I have the a few new TOB's, i also have the speed sensor too.
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
    Bronx NYC (reppin)
    3,489
    why does it look like that trans has been pulled apart before?
    Bronx NYC (reppin)
    3,489
    cosigned, it does look like that trans is missing a few parts also.
    Quote Originally Posted by bronxbombr View Post
    nice i need a hyundai speed sensor for the tranny and eclipse tob.
    yeah that transmission seems to be mission the forks to engage the clutch.
    05-24-2005
    Greensboro, NC
    494
    The guy I bought it from was going to take the bellhousing off and weld it, but decided to part out the car instead. I have the fork, but I do need a TOB. I can go back and see if I get the some of the other parts from the car. I am able to spin the shaft and there play on the shaft. I can wiggle a little up and left and right, could that be cause I'm missing the cover for the shaft?
    its possible cuz technically, nothing is really holding it in place. also it will do you good to seal it back up again if you can.
    I would trash that transmission. Unless you find or know a GOOD welder.
    or just find a bell housing
    Bronx NYC (reppin)
    3,489
    a good Tig or Mig welder can do the job.
    08-04-2003
    NY
    4,344
    TIG it, dont mig it. Secondly, drill a small hole at the ends of the cracks to prevent it from cracking more. All input shafts have SOME play in them, my advice is to replace the bell housing if possible, one, its better than trying to weld that thing and wont cost much more and it gives you the ability to inspect the internals and make sure all is in order. I think I know someone who has a bell housing for that car. the website is Mitsubishigraveyard.com call and ask for Gary.
    99' Galant ES
    4G64/63T
    AEM EMS
    05-24-2005
    Greensboro, NC
    494
    ^Thanks for the info, what should I look for internally when I take the bell housing off?
    08-04-2003
    NY
    4,344
    Let someone who knows what they are looking at check it
    99' Galant ES
    4G64/63T
    AEM EMS
