No.
A 2003 Outlander intake manifold will
will a evo 8 intake manifold fit on a 4g64?if not what will
No.
Anytime buddy
one mor thing does it make a diffrents and is it direct bolt on
The major differ between the galant and the outlander intake mani is the galant one is common to cracking. the outlander isnt. and as far as i know, it is direct bolt on. im actually looking for this myself.
do u know any other bolt ons from other cars just trying to see my options
Youll get a better TB responce since the TB on the outlander is bigger than the stock 4cyl G. Better air flow and stonger intake manifold...outlander TB is a 65mm like the 6g72 G
would having the outlander intake manifold reduce mpg since its bringin in more air? I'm trying to decide if I want to do this as well as get a different throttle body.
The OP: if you're doing a DOHC swap with the Evo head, then YES, you CAN fit the evo intake manifold onto your motor.
someone (i forgot who, maybe someone on club3G) made a list of the Kia and Evo Head supplies needed for the DOHC swap, the evo intake manifold is one of the supplies which fits on a 3G, thus it fits on a Galant motor as well. The highlighted section in the picture is the listing for the evo 8 manifold and various 4G64 parts.
I'm running on an Outlander Manifold. I'm getting a little better throttle response cuz the TB is the same size as the V6 TB. and a lil better gas mileage.
run1206's Rear Disc Tutorial
if you really want an evo manifold on your 4g64 let me know i can have a new flange welded on there that will work.
Cali: Sig 3/28/2011
