Thread: 9G Service Manual
Showing results 1 to 20 of 29
    9G Service Manual
    You can find the download link here:
    http://www.galantforums.net/download...ervice-manuals
    Due to the size of the files I may have to take them down towards the end of the month to save on bandwidth. I will post on the Galantforums.net thread when I have to do that and when it will be back up. Thank you for your understanding.
    www.edelhausrottweilers.com
    rocgalant
    excellente
    KMD20
    thanks
    Thank you so much this is excellent!
    I downloaded it, but how do you open a .rar file ??
    I bought a MUT3 tester as described above..
    I got one of them pretty cheap and it works, it has a laptop with windows 2000 etc to run an sql app.
    It clears all the codes that only a dealer has been able to clear....that's nice.
    It programs the keys as well.
    One of the screens asks for a password...has anyone ever encountered one of these units, and by any chance know the password for the immobiliser section as per the last photo in this list?
    Thanks
    [img width=800 height=600]http://img13.imageshack.us/img13/9654/2systemselect.jpg[/img]
    the links are not working and the laptop that had my manual is dead :' ( can enybody post new links? i'm a "do it yourself"/"get r' done" guy... thanks in advance
    links are not working please repost the links
    Immobilizer code for 9g 1530.
    This would only program the key.
    For key less u disconnect the laptop and only connect the vci. Turn key on, turn vci on real quick hear a beep and keep pressing the hazard light until the lock cycle and press lock and unlock on the remote til the door lock cycle indicating the key less is program then move to the next remote and press lock and unlock. All key less must be program at one shot .
    Links are fine...
    The file link that you requested is not valid.
    please re post the links thanks
    Does anyone have a working link to this?
    Quote Originally Posted by Prophet View Post
    Only part 3 works for me Does anyone have access to part 1 and 2?
    Looks like the free service I was using has alot of problems so I will no longer host the files there but on the Galant Forums.net server. You can find the download to one .zip file here: http://www.galantforums.net/download...ervice-manuals
    Because of the size of these files I may have to take them down every now and again to save on bandwidth. If that happens I will post on this thread: http://www.galantforums.net/forums/9...ce-manual-7239
    When I will take it down and when it will be back up. Hope this helps everyone from having to so many problems with it...
    thanks for uploading but i receive this error
    "The archive is either in unknown format or damaged"
    Uploading or downloading? What browser are you using?
    I just dl'ed the 6-9g manuals and all worked for me.
    ok ill try again...i was downloading, and using Google Chrome
Tags for this Thread
