Thread: 2 step
Showing results 1 to 15 of 15
    TGC Regular P'NOYcaL's Avatar
    10-23-2009
    Bergenfield, NJ
    504
    2 step
    has anyone done this to their 8Gs?
    ________________________________________
    -RON
    08-04-2003
    NY
    4,344
    2 step doesnt do anything on an automatic trans car. Its beneficially on a manual trans car because you can hold the gas to the floor and have the RPMs limited at the point you choose to be best for your launch. On an auto trans you can only do that if your doing a neutral drop which is a terrible idea. When you launch an automatic car you just hold the brake pedal to the floor and hold the gas as far down as you can without the car moving forward then mash the gas and release the brake when you launch.
    99' Galant ES
    4G64/63T
    AEM EMS
    08-04-2004
    Westchester NY
    1,332
    isisnt that called a shutter box?
    08-04-2003
    NY
    4,344
    Its called a 2 step rev limiter. I believe they call them stutter boxes on carburated engines, on fuel injection engines it can typically be done within the ECU so a seperate box isnt needed. There are also aftermarket ignition boxes that have a 2 step feature, esentially all it does is pull timing at a given RPM to cause the engine to max out there even at WOT.
    99' Galant ES
    4G64/63T
    AEM EMS
    07-16-2006
    Cocoa, Florida
    791
    dont evo's have 2 step already? im pretty sure they do, if so i cant wait :)
    10-23-2009
    Bergenfield, NJ
    504
    yeah most evo's have 2 step build, they of course dont come wit that as a stock... i went to this evo meeting 2 days ago and there i saw most of them have 2 step... SOUND SICK!!! some actually look like a flame thrower O.O
    -RON
    i thought the evo MRs come with launch control stock. They do sound nastyy, here is a vid of one with it. http://www.youtube.com/watch?v=B8LZkny54vM
    There are actually three steps to doing a two step.
    1 - Put car in neutral and press the gas pedal so its pegging off the limiter.
    2 - Pull the gear selector down as hard as you can into Drive.
    3 - Yell "Twoooo Steeeepppp" as your transmission explodes with tremendous force leaving you crying and asking yourself why you just did that.
    04-25-2007
    727
    ^^ lol Hahaha... Ive seen two steps gone wrong on evo's as well.. Johnathngalant has it on his 8g but dosen't use it...
    hahah all the evos 8 and 9s have two step and the 10s have launch control for the autos ... I have two step but i cant use it hahaha automatic.. but the break boosting works pretty good if i can stop the spinning..
    08-04-2003
    NY
    4,344
    I cant wait til spring, im gonna launch my car off the 2 step at 12psi@6000rpms, then the boost will be in a progressive ramp by gear, 14psi in 2nd, 20psi in 3rd and 30psi in 4th
    I am amped and this is 4-5 months away. I really wanna see how well the slicks will hold the power.
    99' Galant ES
    4G64/63T
    AEM EMS
    Theres basically two types of two steps, one that cuts fuel, one that cuts ignition. The ignition cuts are safer and more commonly used. Dont get a two step confused with antilag systems that rally cars use.
    I had an ignition cut two step on my old G controlled by an EPROM from DSMChips.com. I could hit 7psi with a 3000rpm rev limit ... but unless I had slicks or drag radials(which I never did), there was no way my FWD with LSD insert and crappy Khumo tires could keep from roasting. I didn't hardly use it, but it sounded cool though haha.
    I road in a buddies 1g AWD with an IPT built auto with stall converter and it had a pretty insane launch.
    07-20-2003
    Orlando, FL
    3,169
    Quote Originally Posted by duh2150 View Post
    Evo X come with a factory 2 step...Previous evos before didn't and had to be added.
    2 step/stutterbox main purpose is to have boost right from the start rather building boost especially in M/T cars. A/T you can brake boost which no need for a 2 step is needed.
    You have to be careful though...you still have to feather the clutch especially in a AWD car. A 2 step at 5000+ rpms with a hard launch will cause some serious driveline shock and prone to driveline failure.
    I have a 2 step/Stutterbox set at 5000 rpms and I get around 8psi from my old Evo 3 B16g setup in my Galant VR4 and it will snap your neck....definite advantage off the dig.
    i just got an evo 9 mr and it deff does not have 2 step lol but my g does.... but i barely use it 2 step kills motors and trannys i do use my no lift to shift alot tho lol
    01-08-2008
    Levittown NY
    2,786
    Yeah evo 8s I believe had a 2 step at 3k. Roman has an evo 8 ecu in his G and I remember my first meet with him he was revving at 2 step with blow off valve going off and some one asked "Are you redlining?"
