ECU is under the radio...its a metal box...
Okay, I'm not a total idiot and I know where the computer is supposed to be. I bought a Chiltons manual and can't even decipher the picture. It tells me to remove the two center console side panels but I had the radio and stuff out today and still don't see anything useful. I need help before I attempt to strip the entire interior out.
Just took mine out yesterday, you are in Luck my friend!
This is for a 96-98 I think, 94-95 are in passenger kick panel.
Take the shifter and the center dash peices off.
Take the side panels of the console off. Your gonna have to remove part of the panel under the steering column also.
Right next to the gas pedal area inside the center column is bracket shaped deal with 3 metal boxes in it. The ECM is mounted to the top inside of the bracket, it's upside down basically. You know it's the right one because it has 2 screws on the front of it.
To remove it you'll have to go to the other side (passenger) and look in the same area. There are two 10mm screws holding that sucker in there and they are a bitch and a half to get to. Once those are undone, pull out all 4 of the wire harness' and slide the ECM towards you and BAM! all good
If that walkthrough sucks, let me know LOL
Thank you very much. The '94-'95 must be the same because the picture in Chilton's is exactly what you described. All the other captions tell you where the damn thing is except the one for the '94-'98. Now I can finish my little project.
Whats the projecT?Originally Posted by DJRINC18
If your just taping wires on the ecu all you have to do is remove the passenger side cover on the center console and the ecu/harness is stairing right at you. Easier to work with if you also pull out the heater vent under the glovebox.
Rob
rIp 97 Galant
starting over.
90 Talon
No wonder when I took out all of that I never saw The ECU (was'nt really lookin for It, But now as I think of it :? )Originally Posted by 2True
YES I STILL HAVE MY GALANT!!
Passenger kick panel is the panel on whatside of the pass seat? I confuse people with that all the time, in 97 atleast there is only a panel on the left side of the passenger seat on the center console the right side is just molding, so I always refer to it as the kickpanel.Originally Posted by MidnightES
Rob
rIp 97 Galant
starting over.
90 Talon
where would the computer be located on a 2001 galant? do you guys know?
woo, old thread and wrong section
passenger side, behind the kick panel on the left side /center console/
im glad someone posted in here cuz i needed this and i was gonna ask 2 double check lol
2014 Lancer Evo GSR
1996 Galant S 5 Speed Turbo
