Thread: Project: Logger for 94 -95 /discussion/
Showing results 1 to 20 of 31
    Very important info that I have found
    https://www.thegalantcenter.org/show...2&postcount=12
    Some good info about 1g loggers and software DLs
    http://mmcdlogger.sourceforge.net/
    As you know 94-95 galants have the OBD 1.5. and because of that the only way to know what is up in the ECU is by counting the CEL flashes, buying a $2000 Snap on tool, or going to the dealership. Well last two can really reach deep in the pocket, and the first one can really spit out the error code and thats it. In many cases, especially after some mods have been done, it is necessary to know the fuel trims, o2 sensor voltages, knock and many other options that a logger can provide.
    /some info on OBD 1.5: http://en.wikipedia.org/wiki/On-board_diagnostics/
    The good thing about Mitsubishi is that they didnt implement OBD2 codes, but stuck with the OBD1 codes. The only thing that got changes was the diagnostics plug. From OBD1 Mitsubishi plugs, now there are OBD2 plug where all wires were transferred and an OBD1 plug that has only one wire to it.
    94-95 Data Link Connector Pinout
    Pin 1: Diagnostic/ECU output (ECU pin 42)
    Pin 2: Unknown/Usused
    Pin 3: Unknown/Usused
    Pin 4: Ground
    Pin 5: Ground
    Pin 6: TCU
    Pin 7: Diagnostic Control Signal (ECU pin 43)
    Pin 8: ABS
    Pin 9: [Alarm]
    Pin 10: Unknown/Usused
    Pin 11: Unknown/Usused
    Pin 12: SRS/Airbag
    Pin 13: Cruise
    Pin 14: Vehicle Speed
    Pin 15: Unknown/Usused
    Pin 16: Power
    When Pin 1 is grounded, the ECU display DTC's just as the 1G eclipse.
    When Pin 7 is grounded(most likely to Pin 4), the ECU goes into diagnostic mode and information from Pin 1 is used to exchange to a scan tool or logger.
    On the 94-95 ECU pinout, the diagnostic pins are 42 and 43, going to pin 1 and 7 of the diagnostic plugs. After doing some research I matched the pins to the 1g ECU which are pins 1 and 2, and came up with some like this:
    And this is how it looks in real time:
    Then got all the other components needed:
    Mitsubishi OBD1 cable
    Palm III xe device with cradle:
    the whole thing:
    Now I havent tested it yet, cuz i just got the OBd1 cable in the mail.
    Thoughts and comments are welcome
    08-18-2004
    Charlotte, NC
    1,029
    FYI, Evo I-III uses the same OBD 1.5 setup and I believe Evoscan can be use to log. :)
    Download for $25.
    http://www.limitless.co.nz/
    1994 GS FYI
    DSM/CSM Manuals
    you might be on to something. if this works you might be able to turn a prophet.
    Download for $25.
    how do i contact these guys? i have to buy something to get to contact information?
    08-18-2004
    Charlotte, NC
    1,029
    Contact: http://www.limitless.co.nz/#Email
    http://www.evoscan.org/helpdesk/index.php?a=add
    Register to Download: http://www.limitless.co.nz/# (Paypal)
    1994 GS FYI
    DSM/CSM Manuals
    08-18-2004
    Charlotte, NC
    1,029
    Right click and Save Target As...
    Palm Hybrid OBD logger
    Since you have a Palm, this is a freebie. Plus I add a homemade RS232 datalog cable diagram for you. Enjoy.
    Edit: Evoscan had a TON load of cool features, the Palm is okay for now.
    1994 GS FYI
    DSM/CSM Manuals
    have u tested this?
    08-18-2004
    Charlotte, NC
    1,029
    Not yet..
    1994 GS FYI
    DSM/CSM Manuals
    08-18-2004
    Charlotte, NC
    1,029
    I'm going to attempt to log my GS this month or March. I guess I will be creating my own cable and using Palm OS which is emulator version of the Palm for the PC. I believe there is a boomslang for the ecu via 94-95 3000GT, which is the same connector as the 94-95 Galant. I have to look into.
    1994 GS FYI
    DSM/CSM Manuals
    I am very interested in this, I just recently squired a 94 GS and I've been looking around this website and this is some excellent information.
    Please continue to add to it
    Here's a recent update:
    I sold the logger
    But i have some else in mind
    I sold the logger
    Do tell what setup your going to go with.
    04-25-2007
    727
    Do you guys think I will be able to read codes with a Openport 2.0 Tactrix cable and evoscan?
    My brother has a GS that has a check engine light Iam trying to fix...
    well thats my plan, just have to buy the cable. i have the evoscan program
    This program something that will work for me in my GS? I'm trying to learn GS specific things and there is not all that much information around.
    04-25-2007
    727
    Ok Kool, I already have the cable with reflash plug. I used it a few times on my evo but haven't got a chance to use it on a galant. I'll be visiting my bro in texas around the 14th, so I will report back with results...
    04-25-2007
    727
    Well I hooked it up to my dads win7 laptop when I was out in texas but the cable couldn't be recognized when using the latest version of evoscan :(...
    I got a winxp laptop that I will load evoscan on and try on my 7g tomorrow and update again...
    briggs
    this is interesting to me, wish I could help. can you list where your purchasing your couplers for the cable etc.
    08-18-2004
    Charlotte, NC
    1,029
    Quote Originally Posted by phizzalot View Post
    I think it needs the drivers installed to recognize the cable.
    In Evoscan I think you either select "hybrid" and 'EFI' for the Hybrid ecu(i.e. 94-95 Galant) or MUT-II.
    1994 GS FYI
    DSM/CSM Manuals
    08-18-2004
    Charlotte, NC
    1,029
    Does anyone have a good electrical diagram of connector C-22[DLC] and C-23[Next to the DLC]. Especially C-23 because I can't find nothing about it. The only information I have on it, is that it is consider as a data link connector as the standard 16 pin connector one but it has 12 pins like the 1G DLC.
    Here is the underdash photo
    1994 GS FYI
    DSM/CSM Manuals
