Thread: 17" wheels - Require anything?
Showing results 1 to 3 of 3
    I was planning on getting a set of 17" rims, and I was curious if new shocks or struts would be required if i was to get a set of 17's? Also - how smooth is the ride with 17's? Thanks in adavance,
    Nick.
    you really don't need anything if u put 17's. maybe some tuner style lugs if ur rims need them and an alignment would be good anytime ur puttin new tires on. but yea optional things would be a drop to make things look better
    wheelsboutique
    you sohuldnt need anything , but depending on what wheel you put or where you buy it from they should come with lugs ( correct for that vehicle) and cetering ring to eliminate vibration if needed.
