Thread: 7g: Best Power Adding Mods + misc. hardware
Showing results 1 to 12 of 12
    This thread is created to inform and explain what power modifications can be done to a 7g Galant. Please post a short explanation and picture to clarify what the modification improves. Please do no ask questions!!! For more info please check out the tutorial section.
    INTAKE
    Short Ram Intake
    Adapter is needed for the MAS sensor
    Minimal gains. It's located in the hot engine bay.
    Cold Air Intake
    You'll see more gains than short RAM. Easiest way to make is from intercooler pipes or customized from another car.
    Throttle Body
    Galant's stock TB is 48mm. 60mm TB off 1g Eclipse will introduce more air into the engine.
    Since the connectors for idle control are different and Mitsubishi TBs are known for their idle surge, a FIAV block off plate is needed to make your idle nice and smooth.
    EXHAUST
    Headers
    Available off 4g63 1g Eclipse. These are not bolt on to the Galants stock catalytic converter.
    High Flow Catalytic converter
    Available from 2 1/4 to 3'' diameter. Will reduce the pack pressure when turboed. The only con is the it will light up your CEL for rear oxygen sensor.
    Cat Back Exhaust
    Available from 2g Eclipse /exp. AWD/ from 2 1/4 to 3'' diameter. Requires a little extending for perfect fit.
    Turbo Chargers and Components
    Turbo Chargers
    13g
    Available off 1g Eclipse automatic. Cons: 5 cm housing, very, very restrictive. Pros: super quick spool up, full boost at around 2k. The turbo is good for low end power.
    14b
    Available from 1g Eclipse 4g63T with manual transmission nand USDM 6g VR4s. Cons: small 6cm housing, very restrictive. Pros: quick spool up. Turbo is good for low to middle range power.
    16G
    Variations: small 16g , big 16g, super 16g
    Available from JDM 6g VR4, Evo 1-3. Pros: large 7cm housing, less turbo lagging. Turbo is spooled by 2800-3000 rpms. Good for mid range power.
    Aftermarket turbos:
    Gaskets
    Oil Feed Line
    DSM Manifold
    Available from:
    1g Eclipse : 2'' outlet
    2g Eclipse 2 1/4'' oulet
    Evo 3 Manifold
    Available from Evo 3 2.5'' outlet, better flow
    Stainless Steel Tubular Manifold
    Available from Ebay 2.5'' outlet Cons: cracking
    DSM turbo housing
    6cm inlet
    7cm turbo housing
    7cm inlet
    DSM O2 housing
    1g Eclipse 2'' inlet 2'' outlet
    2g Eclipse 2 1/4'' inlet 2 1/4'' outlet
    Evo 3 O2 housing
    Larger inlets and outlet than DSM housings 2.5'' inlet/outlet
    Stainless Steel O2 Housing
    Megan SS Tubular O2 housing outlet: 2.5''
    Open Dump Tubular housing outlet: 2 1/4'' or 2.5''
    SS tubular O2 housing outlet: 2 1/4'' or 2.5''
    Downpipe
    Available from Ebay. Inlet: 2.5 - 3'' Outlet: 2.5 - 3''
    Porting and Polishing
    DSM O2 housing ported to 2.5'' inlet/outlet
    DSM manifold ported to 2.5'' outlet
    DOHC SWAP
    Oil passages needed to be plugged. 4g63 head does not use these.
    Camshafts
    Available from many suppliers and durations: 264, 272, 280, 288. Stock 1g Eclipse with manual transmission are 252/252; with auto transmission - 244/244. 2g Eclipse manual/auto 252/252
    Head Gasket and Bolts
    Timing Belt and Gears
    Either adjustable cam gears or 1994 Galant GS timing gears.
    Unfortunately, there isnt a super strong t-belt for 4g64. Only stock available off 1994 Galant GS
    Valves
    Valve Guides
    Valve springs and Retainers
    OEM upgrade for DOHC - Evo 8 springs and retainers
    Aftermarket
    3rd Gen Lifters
    Valve Stem Seals
    Cyclone Intake Manifold
    Sheet Metal Intake manifold
    ENGINE
    Pistons
    Connecting Rods
    Crank Shaft
    Bearings and Bolts
    Evo 3 Oil Housing
    Allows to run external oil cooler on 7 bolt block.
    Balance Shaft Kit
    Reduces rotational weight. Engine will rev faster and higher.
    Pulleys
    These reduce rotational weight. Engine will rev faster.
    DRIVETRAIN
    5 Speed Swap
    Transmission off 2g GST or 7g Galant
    Clutch Kits
    Exedy
    Act
    Flywheels
    Fidanza 8 lbs
    Act 12.5 lbs
    Transmission Oil
    Limited Slip Differential
    Full
    Insert
    Full Transmission Rebuild Shepherd Transmissions, Jacks Transmissions, DogBox Transmissions
    AWD conversion Every part comes off 2g GSX
    SUPPORTING MODS
    Intercooler, Pipping, T-Bolt Clamps and Silicone Couplers /Reducers/
    Boost Controller
    Electronic
    Manual
    Blow Off Valve /BOV /
    Fuel Pump and Filter
    Fuel Pressure Regulator /FPR/
    OEM off 2g Eclipse GST or GSX
    Aftermarket
    Injectors
    OEM upgrade
    Blue tops DSM 450cc
    Yellow Tops Evo3 510cc
    Aftermarket: Denso, PRE........ACCEL
    High Speed Fans
    Aluminum Radiator
    Fuel Controllers
    MAFT
    SAFC I, II, Neo
    SAFC II
    Neo
    Stand Alone Engine Controller
    AEM EMS
    Megasquirt
    ECU+
    DSM Link
    more....
    Bow to the brothers
    Thanks for write up
    http://www.gasketer.ecrater.com/
    get you OEM parts with low price
    04-25-2007
    727
    NICE MKO don't forget Evoscan/Ecuflash for tuning and evo8 ecu compatibility...
    Hey just wondering if I put some EVO 3 injectors in my 4g63 N/A would I need to upgrade anything else for it to perform properly? Like airflow meter?
    Thanks
    TGC Regular Boosted's Avatar
    12-03-2008
    Fayetteville, NC
    575
    No, not unless you are running an engine management system.
    I need power asap am auto so first step would be go manual?? I got cai, 2.5 full exhaust and no balance shaft still too slow i need sonethign beter and i i plan to go turbo, manual tranny would be a priority right?
    damn! How did I miss this write up? Good job!
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
    12-18-2008
    Central Kentucky
    805
    Do the headers need to be from specifically a 1g eclipse or will any 4g63 header work?
    do you know of any other 4g63 N/A cars?
    12-18-2008
    Central Kentucky
    805
    Idk that's why I asked.lol
    TGC Regular eclipsh's Avatar
    09-06-2008
    SW Colorado, USA @ 7600 ft
    533
    The only way to make much power on a 4 cylinder is to rev it to the moon or go forced induction.
    I'm sure someone has built a destroked NA (naturally aspirated) '64 at this point. That would be the way to get high revs. I'd be trying to hit 10-11k which would require some serious work to the tranny too. The plus side is the tranny is less likely to break so long as the shift forks are tough. NA motors are also very responsive. The downside is that it would be very expensive for not a lot of power.
    Forced induction is the only way to make substantial horsepower. It can also be made relatively cheaply. The downside is it is less responsive than an NA. Some of the same tricks for NA apply to FI engines, ie: cold air intake, larger throttle body, higher flowing exhaust. Turbo engines make more power down low which is hard on gears but easier to shift.
    The information on a limited slip differential is very important for FWD cars. Without one you'll just smoke one tire and not accelerate. The inserts are not recommended by Team Rip Engineering, a specialist in DSM transmissions. The reason is that they wear out your front differential and can cause failures that take out the rest of the transmission. If you plan on staying FWD do it right and go for a clutch or mechanical LSD such as Kaaz or Quaife.
    08-18-2004
    Charlotte, NC
    1,029
    Quote Originally Posted by eclipsh View Post
    I'm working on it on the NA part... The long rod combo on the 2.4L is good for 9K rpm just need very good cams with a rapid ramp rates like JUN 272 or Kelford 272, along with a good header and IM combo.
    An Evo I-III Front LSD from Ralliart or FTO LSD but their are hard to find and expensive.
    1994 GS FYI
    DSM/CSM Manuals
