Thread: A few Questions on the DOHC head Swap
Page 1 of 2 12 LastLast
Showing results 1 to 20 of 40
    11-29-2009
    Chadds Ford, PA
    2,768
    Sorry i know this has been discussed before but its just not clear enough for me, I would like to swap to and evo head, would i have any issuses with clearence between the pistons and head, or would i have to get new pistons, i would like to stay NA for awhile until i can go turbo. Also would i need an EVO ecu or would a stock ECU work fine???? Also would i be able to use and 2.0l lancer head??
    Moderator mko's Avatar
    09-20-2007
    Sea Isle city, NJ
    4,098
    I think you should be fine with clearance.
    No need of turbo ECU if you dont have a turbo, stock is fine.
    2.0L Lancer head is SOHC almost similar to the one you have, so no point to do that.
    Build Thread
    11-29-2009
    Chadds Ford, PA
    2,768
    SOrry i didnt specify it is a DOHC
    09-20-2007
    Sea Isle city, NJ
    4,098
    then yes it will fit
    Build Thread
    11-29-2009
    Chadds Ford, PA
    2,768
    so it would be the same as a regular evo head swap, and i would not need pistons correct??, is basically sounds like pull and drop with a few modifacations?? Also what would it take to do a mivec head??
    TGC Regular Boosted's Avatar
    12-03-2008
    Fayetteville, NC
    575
    IMO, you should reprogram your current ECU or run an Evo ECU due to the fact that you will be running a DOHC head over a SOHC. As far as I know the Lancer head wouldn't be compatible so throw that out the window. This is a direct swap. You can use the stock pistons from an Evo head.
    The MIVEC head swap isn't worth it IMO unless you plan on spending big money for specially produced cams, cam gears, and other power adders since there aren't alot of mass produced aftermarket items for the MIVEC platforms. And you also have to take in account that these motors haven't been proven to bolt up to our transmissions as of yet.
    11-29-2009
    Chadds Ford, PA
    2,768
    Quote Originally Posted by Boosted View Post
    Thanks man for the mivec info it was well needed. DO you by chance know what the compression ratio roughly would be with the DOHC, my boy seems to think it will lower it since it comes off a turbo car.
    08-18-2004
    Charlotte, NC
    1,029
    Depends on which 4G64 you have: Some are 9.0:1CR while others are 9.5:1CR. Also depends on which DOHC head you use.
    1994 GS FYI
    DSM/CSM Manuals
    11-29-2009
    Chadds Ford, PA
    2,768
    Ok since i dont know my compression ration would it lower or raise it from stock??
    08-18-2004
    Charlotte, NC
    1,029
    depends on the which DOHC head you use
    1994 GS FYI
    DSM/CSM Manuals
    11-29-2009
    Chadds Ford, PA
    2,768
    i would be using an evo
    TGC Regular
    07-16-2006
    Cocoa, Florida
    791
    It would raise your comp to around 10.5:1 so if your planing on using the evo head plan to buy some pistons
    <a href="http://s40.photobucket.com/albums/e202/duh2150/?action=view&amp;current=crownvicbannerpart3.jpg" target="_blank"><img src="http://i40.photobucket.com/albums/e202/duh2150/crownvicbannerpart3.jpg" border="0" alt="Photobucket"></a>
    11-29-2009
    Chadds Ford, PA
    2,768
    i woulnt need to if i run na?? i know for boost i would need and 8.5-8.7:1 ratio, and the 8.5:1 pistons they make are they for the SOHC??
    TGC Regular
    07-16-2006
    Cocoa, Florida
    791
    who make? anyways if you put the head on there your going to have to take it back off to change out the pistons, i don't think the na lancers are even a 4g63, i think you need to go back and do more research, because you keep bringing up SOHC, it most likely will not fit, no one tried and no one has parts for a 4g64 with 4g69 head if they do id be really surprised, just go with a KIA head keep the stock pistons and boost a little
    and you need custom 4g64 pistons nothing else, no evo pistons no lancer pistons, just 4g64 pistons if you wanna go NA all the way add in some kia pistons i don't think anyone tried it yet it will have you at like 12:1 CR, but that might not work
  15. #15
    11-29-2009
    Chadds Ford, PA
    2,768
    Eventually one day i would like to go to boost, and with a 10.5:1 compression ratio boost would be outta the question for awhile, i like to keep head not lift them. The reason i said SOHC is that they make 8.5:1 pistons for the stock 4g64. But since i am wanting to put an evo head on there it would raise the compression ratio from 8.5:1 to whatever. i am saying this baised upon what you said, stock compression ratio is around 9.0:1, dropping evo head on bring it up to 10.5:1. thus raising the compression.
    honestly taking the head off to do pistons does not bother me.
    why would i not be able to use 87.5mm evo piston, if i am not mistaken that is the bore of our motors??? so using an evo piston with an evo head would give me a stock evo compression ratio. of roughly 8.5:1. isnt this what most evo guys do?? get our block our crank and rods and use their pistons with their head, giving them a higher torque motor along with literage??
  16. #16
    08-04-2003
    NY
    4,344
    Its not that simple. Buy the correct pistons for the setup your doing, the 4G64 block is taller, the piston at TDC sits at a different height than the EVO, the wrist pin is in a different location, its not the same piston, get the RIGHT piston for your setup. Using larger bore EVO pistons has been covered a hundred times and nothing has changed, you still cant use them.
    99' Galant ES
    4G64/63T
    AEM EMS
  17. #17
    11-29-2009
    Chadds Ford, PA
    2,768
    SO i take it the right piston would be custom? since the standard 8.5:1 would be too high with and evo head??
  18. #18
    09-20-2007
    Sea Isle city, NJ
    4,098
    I dont see how the Evo head will raise that much. I mean the stock CR is 9.0:1 and to go to 10.5:1 is very weird. Even if it goes to 10.5:1 it will be awesome for NA driving and youll still be able to boost it with smaller turbo and run 8-10psi.
    My believe is that CR wont go over 10:1.
    Build Thread
  19. #19
    08-04-2003
    NY
    4,344
    It has to do with combustion chamber volume. The volume of the combustion chamber on the EVO head is smaller than volume of the SOHC head, this is what causes the increase in compression ratio.
    99' Galant ES
    4G64/63T
    AEM EMS
  20. #20
    Yea it only should just by about 1.0:1 at most.
    I hope you know that the pistons you are going to be looking for are not going to be custom right? Manley makes a really nice set for a good price and all 4g64 blocks have the same bore so even if you find one that says application for a 1996 eclipse spyder it will still work cause its the same piston.
    Kia head is basically the same thing as the evo head minus mivec and minus the evo cams, and most likely smaller intake and exhaust ports and valves which could be fixed by having the head ported and putting in evo cams and valves. Mivec is pointless to me, really so go with a evo 8 head or the kia head and you will be happy.
    the 4g69 head will not work because the head is narrower and the bolt pattern is not the same so move away from that idea right now unless you want to plug and and retapp the block.
    1996 galant s
