Thread: Manual tranny, EVO ECU setup w/boomslang harness
Showing results 21 to 40 of 83
    10-18-2007
    Glen Burnie, MD
    1,314
    How come I saw drew say the evo is a 2 row and we have a 3 row?
    well mko has a 7g, where the TCU is seperate from the ECU.
    IIRC, the Evo and eclipse M/t ECU has 2 rows and are pinned out 99% the same. the galant (all auto) and eclipse A/T ecus are 3 row.
    08-15-2006
    Perth Amboy, NJ
    1,558
    thanks qnz, that's what i meant.
    I checked the Boomslang website and the closest thing I saw was an extension harness for the evo 8, not a conversion harness. With that said, I assume it's a custom harness so i'll call them up tomorrow and see if they can make me a conversion harness. Might be another few hundred. :(
    run1206's Rear Disc Tutorial
    04-02-2009
    Denver Colorado
    1,447
    Ok here is the kicker though. How are you guys wiring up on the stock Galant Ecu after the manual swap? Aren't we already bypassing the Ecu to think it has an A/T in it? We can still use the A/T Ecu in the 01+ Galant and just reflash that without having to worry about this M/T Ecu stuff from mixing into all of this.
    Keeping the G's A/T Ecu in tact, wiring all the same, and doing a reflash eliminates the need to do any boomslang or other harness configurations...which also saves money from being spent where its not needed.
    www.blackheartmotors.net
    04-02-2009
    Denver Colorado
    1,447
    Ding ding...
    http://www.club3g.com/forum/gt-gts/1...ml#post2771936
    Yup, still just using EcuFlash. So far its workin pretty good.
    08-15-2006
    Perth Amboy, NJ
    1,558
    but i'm going turbo and i'm manual. even if you swap the roms over to the Galant ecu, it won't read over 100%. For now, that's ok, but when i go turbo, it's a problem. I already spent the money on the harness and evo ecu. I'm planning on using the evo ecu for those maps; they're already built in. my problem is would it be the right harness. I don't wanna mess with the Galant ecu cuz i'll use that as backup in case something goes wrong.
    04-02-2009
    Denver Colorado
    1,447
    Quote Originally Posted by run1206 View Post
    Yes, you are going Turbo which is still forced induction like the SDS is, and follows similar parameters which many folks on C3g can help, or even assist you in tuning for the turbo.
    Whether you are manual or not, the stock ECU is still seeing an A/T Transmission in the car due to the "hack" on the wiring when you just do the Manual swap in our cars. So switching to a manual Ecu is not really needed even.
    The Maps set in the Evo ECU can be read and added to your Ecu when you Flash it, just have to change the OEM parameters on the G's Ecu to correspond the Evo, but again we would need to figure out the MAP sensor and boost reading from that. I believe Dragon34x has figured that out since he is able to tune with his boost (sucessfully none the less even). I will hit him up for more details on what Ecu he is using, but I am almost certain he has retained use of the OEM 3g's Ecu.
    08-15-2006
    Perth Amboy, NJ
    1,558
    i dunno. Roman's had his evo ecu in his car for years, so has Aaron and Brian.
    08-15-2006
    Perth Amboy, NJ
    1,558
    i was gonna PM him but i might reply on his thread. i'm curious as well. Might look into it a bit more.
    04-02-2009
    Denver Colorado
    1,447
    Yea a lot of people have been running the Evo ECUs on this and other platforms. The Ecu flash stuff has started being picked up on more now because more people are finding its a viable tuning option. It has been picked up on since 2006, but nothing really put into the works for about a year maybe on Club3g...but now its becoming the "hot" item vs what has bee used previously.
    Its just something a lot of the Galant community hasn't picked up from yet it seems, and I just wanted to let you and others who read this that there are alternative options for people with 01+ 8Gs, even some of the 00 Ecus can be flashed depending on the processor inside, but this is definitely something we all have to look into a lot more since it is being used very well by numerous others to date.
    I am actually doing an 01 ECU swap into my 99 just so I can tune via EcuFlash and log from Evoscan on my build (which is a TT build...not N/A).
    Definitely hit him up on it man, those guys are deep into the EcuFlash stuff over there.
    10-18-2007
    Glen Burnie, MD
    1,314
    So its possible to load the evo maps onto the 01+ a/t ecu? Now I just went out and bought a net book and gonna get a 2.0 tactrix cable so I can hook it up and take a look at things. Couldent i just disable the processes that check the system aka for the trans codes its throwing?
    04-02-2009
    Denver Colorado
    1,447
    Quote Originally Posted by WhiteGalant View Post
    I haven't looked at the Evo maps very much honestly, so i cant say for 100% certainty tht you can just load the entire Evo map. It would be good to take a look at some of the key things on the Evo map that are different than the OEM map on the G, such as timing and fuel portions, but keep in mind these are preset for the boost levels of the Evo from the factory.
    Once you get the cable pick up the EcuFlash stuff from OpenEcu.org, purchase the EvoScan ($25), or download the free MitsuLogger software and do some logging of the stock maps. You can easily alter the OEM maps/parameters per your build, just loading an Evo map will require some alterations for us as well I would imagine.
    I am unsure if you can diasble those parameter in the Ecu, but then again I am not sure what codes are being thrown on the 5spd swapped 01+ 8gs either.
    Sorry if I'm repeating information cuz I only read most of the first page
    from what I remember reading that the eclipse guys load up the Evo rom into their ecu for better fuel maps or something along that line which is what our stock ecu is limited cuz we have the automatic and not manual trannies in our cars
    I remember flashbluers was doing all this ecuflash stuff for a small fee but I think he stopped but u can double check
    So either using evo ecu or eclipse ecu and no need for our stock ecu. Conversion harness is an easy route (how much are those anyway ??) or you can de-pin yours and re-pin it to the eclipse ecu or cut and solder them in. Maybe it's more time consuming but saves you money :-)
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
    05-03-2007
    Socal/Central Coast
    3,803
    this is what I wanted to do but I don't want to get a code b/c of the 5 speed. Still need to pass emissions
    04-02-2009
    Denver Colorado
    1,447
    Just keep a watch on the build thread...I have to do the same thing.
    08-15-2006
    Perth Amboy, NJ
    1,558
    i'll contact some of the guys on club3G later tonight about the flashing of ROMs to their ECUs. Still researching the situation in the meantime.
    05-03-2007
    Socal/Central Coast
    3,803
    Hey run1206, so do you know what codes you are throwing on the 2002 ECU?
    08-15-2006
    Perth Amboy, NJ
    1,558
    the usual 5 codes
    4 for the four shift solenoids (the four gears that were in the automatic)
    1 for the torque converter solenoid
  19. #39
    05-03-2007
    Socal/Central Coast
    3,803
    actually shoot I think we need to know the codes that the 01 ECUs are throwing
    thanks though
  20. #40
    08-15-2006
    Perth Amboy, NJ
    1,558
    wouldn't they throw the same if it's from auto to manual? :?
    and the 01s can go to the 2000 ECU (i think, don't remember what Roman said about the 01 ecus for the swap)
