Thread: Manual tranny, EVO ECU setup w/boomslang harness
Showing results 41 to 60 of 83
  1. #41
    05-03-2007
    Socal/Central Coast
    3,803
    Quote Originally Posted by run1206 View Post
    wouldn't they throw the same if it's from auto to manual? :?
    and the 01s can go to the 2000 ECU (i think, don't remember what Roman said about the 01 ecus for the swap)
    not sure if they throw the same codes or not
    but the whole point of my post (and SPD_FRK I think) is because we can't flash/tune our 99 ECUs, so we are looking for another option besides a stand alone that won't throw any codes with the 5 speed swap
  2. #42
    08-15-2006
    Perth Amboy, NJ
    1,558
    from GOOSEY's thread:
    COMPATIBILITY
    1999-2000: NO CHECK ENGINE LIGHT, NO PROBLEM
    unless you're throwing other codes non-related to the tranny swap.
    run1206's Rear Disc Tutorial
  3. #43
    04-02-2009
    Denver Colorado
    1,447
    If everything is wired up correctly on a manual ECU it may not throw any codes, but that would require a deeper look into the Manul ECU wiring and comparing to our A/t ECU wiring to see if its possible.
    Correct, 99-00 (with an exception to certain 00 ECUs), we cannot flash or tune unless we use an Emanage or similar piggyback/standalone system. The possibility of doing the 00 ECU swap, and flashable, while removing codes from being thrown is there, but it is a hit/miss unlss you get the specific processor that is used on the 01+ ECUs...which can make it difficult to buy an ECU online.
    This is why we need to know what code specifically is being thrown for the 01+ 5 Spd swapped Gs so we can see if the parameter in the ECU can be altered/disabled, or a bypass put in place.
    www.blackheartmotors.net
  4. #44
    10-18-2007
    Glen Burnie, MD
    1,314
    I can get the exact codes in a few minutes, lemme finish eating and ill go out and hook up my scanner.
  5. #45
    04-02-2009
    Denver Colorado
    1,447
    Quote Originally Posted by WhiteGalant View Post
    You better share some of that Steak with the rest of us boyeeeeeee!
    I will dig up the info on the 00 ECUs as well so people know what exactly to look for.
  6. #46
    10-18-2007
    Glen Burnie, MD
    1,314
    Haha! Steak?!? I fuckin wish... Mini microwave tacos... LOL
  7. #47
    10-18-2007
    Glen Burnie, MD
    1,314
    p0753 Shift Solenoid A
    p0758 " " B
    p0763 " " C
    p0768 " " D
    p0743 Torque Converter
    TaDa!
    Time to go poo now LOL
  8. #48
    04-02-2009
    Denver Colorado
    1,447
    p0758 " " B
    p0763 " " C
    p0768 " " D
    TaDa!
    Thats good information, and too much lol.
    So from those codes it is still searching for the individual shift solenoids, and the converter one throws me off...not sure what its looking for on that. Is there a sensor I am missing for the TC?
  9. #49
    10-18-2007
    Glen Burnie, MD
    1,314
    I have no clue, guess ill have to take a look at the fsm and see if there is a sensor for the TC.
  10. #50
    04-02-2009
    Denver Colorado
    1,447
    I believe I found the solenoid information in the FSM. These are a part of the Valve Body like I assumed, and I found the one I believe is connected to the TC code;
    2. UNDERDRIVE SOLENOID VALVE
    3. SECOND SOLENOID VALVE
    4. TORQUE CONVERTER CLUTCH CONTROL SOLENOID VALVE
    5. OVERDRIVE SOLENOID VALVE
    6. LOW-REVERSE SOLENOID
  11. #51
    10-18-2007
    Glen Burnie, MD
    1,314
    So... how do i fix it lolol
  12. #52
    04-02-2009
    Denver Colorado
    1,447
    No idea yet, still sifting through the FSM. The harness we would have to focus on for those codes though is the Valve Solenoid Harness for sure, but trying to figure out for sure if the TC solenoid is on that harness as well or not. I may have to just pull the VB out of my A/T and see. There has to be something additional on the 01+ ECU though that is being overlooked/missed to cause these codes to pull up considering the same transmission has been used through all the years, unless they changed up the VB solenoids or something.
  13. #53
    04-02-2009
    Denver Colorado
    1,447
    What year G do you have? Still got your A/t sitting around?
    The FSM specs on the Solenoid valves are pretty general, no specification or year variations and each solenoid shoud read 2.7 − 3.4 Ω between the two terminals. This makes me wonder if a simple resistor pack or something similar would work to give the ECU that specific range of feedback if we spliced it into the harness...hmmmmm
  14. #54
    10-18-2007
    Glen Burnie, MD
    1,314
    Its an 03
    Yea I still got the trans sitting out in my driveway. What U said about the resistor pack, goosey tried that and everything was good until he would put the last resistor in and it would smoke it. i think a resistor fix is out of the question.
  15. #55
    10-18-2007
    Glen Burnie, MD
    1,314
    Throw some ideas at me ill give anything a shot lol. Oh yea I also need to figure out the wiring for the speedo.
  16. #56
    04-02-2009
    Denver Colorado
    1,447
    Its an 03
    Any idea if the information is posted somehwere? Id be interested to see what resistor it was that fried, or how he wired them in as well.
  17. #57
    10-18-2007
    Glen Burnie, MD
    1,314
    Ill see if I can find it hold on...
    Edit: Here take a look at this...
    https://www.thegalantcenter.org/show...ht=manual+swap
  18. #58
    04-02-2009
    Denver Colorado
    1,447
    Cool, I posted in there to get some specifics on the 5th one that kept giving issues. To me I assume its the TC solenoid giving some negative feedback and causing the problem if the other 4 (which are just shift solenoids anyways) worked fine.
  19. #59
    10-18-2007
    Glen Burnie, MD
    1,314
    I was thinking of pulling the plugs out of the auto trans so that I could use them to link the reverse solenoid wires as well as pins 9+10 for ignition. I guess at the same time maybe do a little picking at it lol.
  20. #60
    run why are you worrying about shift solenoids?? From what i read you are running dual ecus?? worry about the evo ecu codes and remove the check engine line from the auto ecu.. If your going 5 speed.. ask boomslang to send you more pins and add the additional pins to the harness.. no need to buy a new harness.. you will just not use the stock side...
