It sounds like you're backfiring....from running rich.
Could be a faulty sensor (check engine light should be on)
could be that your timing belt jumped a tooth...
Been having this problem for a while. Seems like when i start my car up i feel it shake a little bit and from the exhaust i hear popping sounds. Kinda like muffled popcorn popping. While driving I feel it popping also I noticed that I'm consuming more fuel than before. Had my wires and plugs changed recently, seemed to have only helped a little
What could this be?
"Speed never killed anyone. Suddenly becoming stationary...that's what gets you." - Jeremy Clarkson
1997 Galant ES with '94-95 style front end and '97 style rear
check if your plug are wet or spark plug
