Thread: 18" rear wheels rubbing fender welds
Page 2 of 2 FirstFirst 12
Showing results 21 to 34 of 34
    03-12-2007
    Dallas TEXAS
    2,041
    Quote Originally Posted by greddy View Post
    OFFSET problem.....
    nothin a good fender roll cant cure lol
    Offset and backspacing affect how the wheel sits on the car. And in fact that *can* also affect your alignment specs (toe, camber, and scrub radius). Just roll the fenders and call it a day.
    i'll check the off-set, if all else fails i'll have to roll the fenders...
    Sparky-
    check out my ghostrider by this link-
    http://www.cardomain.com/ride/2399130
    anyone know where you could get something to roll fenders with?
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    You should check a wheels shop
    4g64T 5spd
    Guys, I finally had my car aligned and the shop stated that the cause of the rubbing was my backspacing/offset of my wheels. I researched and the wheels I had prior (Fame Exel 18x7.5 offset 40) did not/and or never rubbed. My current wheels (R-1 Racing Drift 18x8 offset 40, offset HPO) rubs. The shop stated that my only other option is to have my fenders rolled. The difference between 18x7.5 and 18x8 wheels=rubbing? That's nutts!! Holla at me if I'm on the right track and if my information is correct-Sparky!!!
    Sparky-
    my prior wheel (fame exel) i got from wheelmax.com and my current wheel (r-1 racing drift) i got from wheelsnext.com ....if someone wanted to check behind me these are the sites to visit.
    Sparky-
    04-29-2009
    Holyoke,Massachusettes
    3,600
    ^^^^^ definatelyoffset.
    FreakyDeaky
    2kG 6g72/74 5 speed
    Quote Originally Posted by Kat Daddy View Post
    Quote Originally Posted by Corey2000Galant View Post
    Did you read his post just two posts above yours?
    What do you think the only difference is?
    04-29-2009
    3,600
    just wanted to put it lol...
    FreakyDeaky
    2kG 6g72/74 5 speed
    05-03-2009
    1,465
    Damn so .5" really makes the difference for you, rolling fenders would be the correct fix or add a little neg camber like Stewi said.
    4g64T 5spd
    07-12-2007
    SoCal
    4,632
    Yes that small amount of differnece is enough to cause rubbing. Roll your fenders and call it a day.
    JDM Zenki Conversion
    Actually it is only .25" that is making the difference. A half inch total is .25" on each side. Although the backspacing of both wheels can be up to .25" different also.
    05-03-2009
    1,465
    Right right, .25" to each side, my bad.
    4g64T 5spd
