Thread: wtf??? intake problems
Showing results 1 to 9 of 9
    hey guys. i got a 06 galant 2.4l auto and i was trying to get some better gas milage out of it so i made an intake for it. i removed the old air box and installed a short ram intake. after driving it for about 15 minutes the check engine light came on and it throwing a "system too lean bank one and 2". i check the 1 vacuum hose it has to the intake and made sure it was hooked up and sure enough... it was. i erased the code and it came back on after driving it for another 10 minutes. has any one had this problem before when in stalling an intake on there 9g?
    Experienced TGC Member
    10-18-2007
    Glen Burnie, MD
    1,314
    Do you still have the MAF installed?
    yes. i got an adapter to use the maf but its right behide the air fiter. the o ring is sealed tight in the adapter so it shouldnt be leaking from there either.
    12-27-2005
    Charleston SC
    1,520
    Maybe you should try resetting the ecu. BTW. did you install the maf correctly?
    TGC Regular P'NOYcaL's Avatar
    10-23-2009
    Bergenfield, NJ
    504
    hmmm maybe u didnt disconnect the battery while installing?..
    ________________________________________
    -RON
    u made an intake? the sensor is pretty sensitive, even injen hand problems at first with the check light... buy a fujita, problem would be solved
    uhhhh...... Whats a 9g???
    Generally I'd say reset the ecu, its probaly sensing the wrong airflow, since you are increasing flow thats probaly why you get the light/error codes, reset the ecu and see if it throws you the same code, had this problem on a few cars back in the past, resetting worked wonders.
    How does the engine idle? / Any Problems driving at all? or Just the light?
    the car ran fine but and it was just a light. i took it off and the light never cam back on so in just going to buy a regular in take just for the car... just got to save some money.
