I been searching for the whole day and i remember someone said you can use a ss clutch line but i wouldnt think it would fit but any info would be a blessing at this ppoint
So I been looking for a shifter cable for my 1998 manuel gallant like for 4 months and I found nothing. I bought two different ones from someone off this site and they both didn't fit so I wasted my money I found a junkyard that has the shifter cable but its for a 94 so I'am like yeah it should fit but then the guy calls me and says its two different part numbers and I dont I wanna waste my money again so my question is will it fit and also is there anywhere that sells the shifter cable or is there any after market piece i can replace it with please let me know asap I Miss my car
clutch line
http://cgi.ebay.com/ebaymotors/EAGLE...item29f84118f0
94 thru 98 shifter cable are the same
thankyou i hope your right I dont want to spend anymore extra money
I dont think thats the rite part the shifter cable looks more like this and the same problem happen to me here the video
http://www.youtube.com/watch?v=zsUG9rGtBiA
like me, I used a 94 2g shifter cable.
http://www.gasketer.ecrater.com/
get you OEM parts with low price
okay so a 1994 shifter will fit
thanks I will visit the junk yard but i lost the original shifter so i cant compare
where are you located at because my junk yard i have a lot of 98 galant
I'am in long Island New york lmk i might be able to travel because the junk yard claims no one can take it out for me
thanks for all the information
yeah but you take it out yourself that what i do around my junkard
Yeah I"am probly go there see if I can take it out
does anybody know if AN 2g eclipse shifter cable will fit as well
exact fit
except 420a eclipse, not sure about that
no the NA cables are different. Also 94 is still considered to be a 1g and these cables come a bit short. 2g Eclipses that are preoduced in 94 for 95 market, then yes. Just make sure its either GST or GSX
yeah, he is right. Mind was 96 so i use 96 GSX shifter cable
Here's your link...
http://www.machv.com/1gdsmshca.html
I would call and verify that they will work on your model...
2G turbo shifter cables fit for sure. nonturbo/NA 2G shifter cables will not work. not sure about the 1G, play it safe and get 2G turbo shift cables. also, that link mko posted for the clutch line will fit and work with your car no problem
