Thread: Parking light fuse location
Showing results 1 to 2 of 2
    RadRICH - TGC Founder BGR's Avatar
    12-09-1999
    FLORIN - Sacramento, CA
    1,996
    If you know you've blown the fuse because of a short, and either side of your parking lights doesn't turn on (but your hazards work - indicating that the bulbs are good), check the fuses located here:
    {{next to these fuses are the high and low beam fuses}}
    I see you figured it out, I was just looking at that.
Tags for this Thread
