Thread: 94-95 ecu plugs
Showing results 1 to 11 of 11
    08-18-2004
    Charlotte, NC
    1,029
    94-95 ecu plugs
    Does anyone know if the 94-95 harness[plugs] are the same dimensions as the 2G? I know the 94/95 have three plugs while the 2G has four, but will the plugs fit/connect to the 2G ecu?
    1994 GS FYI
    DSM/CSM Manuals
    08-18-2004
    Charlotte, NC
    1,029
    Icon4
    Okay. If I'm right about this, we 94/95 owners can use 3G/Evo 8 Ecus w/o cutting up the stock harness...
    1994 GS FYI
    DSM/CSM Manuals
    the only thing i know for sure is that the 97-98 plugs work fine for the 2G ecu. because all you do is repin the connectors and they both use the same 4 connectors.
    08-18-2004
    Charlotte, NC
    1,029
    Well, from the looks of it 3 plugs from the 94/95 harness is the same as the 2G/3G except for that 12-pin plug.
    1994 GS FYI
    DSM/CSM Manuals
    so all you do is add the plug and your set after moving a couple pins around
    08-18-2004
    Charlotte, NC
    1,029
    Quote Originally Posted by kolio View Post
    kool, just need a extension harness, 3G ecu, evo rom, and cable.
    1994 GS FYI
    DSM/CSM Manuals
    it's cool because we got alot of options for ecu's now. i like the evo ecu idea
    08-18-2004
    Charlotte, NC
    1,029
    3G/Evo8
    94/95
    Notice the 16, 22, and 26 pin plugs are the same.
    1994 GS FYI
    DSM/CSM Manuals
    the plugs are the same, but theres a difference in the pinout diagram. i really thought of that - using the Evo8 ECU, but Its much easier to use Evo1-3 ECUs since they are P'n'P for 94-95 Galant.
    12-17-2002
    Sherman Oaks, California
    4,304
    what's this talk of 4 plugs for the ECU on the 7G harness?? it only has 3
    http://socallifestyle.com/
    1994 Galant GS 5spd
    Quote Originally Posted by peanotation View Post
    not the 7G B's (97-98) we have 4
