Thread: 8G Dome Light Breakdown and Cleaning
Page 1 of 3 123 LastLast
Showing results 1 to 20 of 42
    01-19-2007
    Lyndhurst, NJ
    3,473
    This tutorial will show you how to effectively take apart and clean your overhead dome light in your 8G. Also this is great if you want to change over from your bulbs to LEDs. Disclaimer: Don't blame me if you fuck your shit up. =)
    We start by removing the dome light from the car. In order to remove it we need to just pull it out of the headliner. It is not attached by screws. However, you do need to unplug it. Just push the tab in on the plug and you should be able to pull it out.
    This is what you need in order to get this dome light taken apart.
    Yes, just a philips head screwdriver. You need to flip the dome light over to show the bulbs, those need to be removed first.
    In order to remove them you must apply pressure to outer tab so that the bulb can unhook from it.
    Once it is unhooked from the one side, it should just slide off of the inner tab.
    Once the bulb is out, this is what you should have.
    Please repeat same exact steps for the opposite side. This is what you should end up with.
    Once the bulbs are out you can stick your finer into where the bulb used to be to push down on the lenses so that they can pop off.
    You should get something like this when you push your finger through.
    Remove the plastic lens by pulling inwards towards the switch on the dome light because it does have a tab.
    You should end up with this.
    Repeat for opposite lens. You should end up with this.
    Here we are removing the buttons that control each bulb. These are very easy to remove. Just grab them and slide outwards.
    Do the same exact thing on the other side of the dome light. You should end up with this.
    Once those are gone, we can worry about the big selector button. You want to start by removing the philips screw.
    Be careful when you are removing the screw because there is a small metal ball and a spring that will come off with the button. This is what you should get after removing the screw. *Notice* the metal piece has a cut out for a tab so that you put it back on the right way!
    Now before we flip the dome light over you want to sneak your thumb underneath it and hold that button in place so that you don't lose the ball or spring. They are greased so the spring might stick to the switch and the ball might stick to the dome light. Mine did.
    Flip it over and pull the switch off. You can see the small spring still inside the button.
    Here you can see the ball on the dome light.
    This is what you should get when you have taken everything out.
    The only pieces you would want to clean is the button, lenses, and the actual dome light. Nothing else will be seen. Jeez, look at how dirty this thing is.
    Then would you would want to do is just run it under some soap and water and clean the lenses and button with your hands. Do the same for the dome light, but you might want to use a tooth brush to get into the letters on the light. You might get some gunk in there. Here is an after shot.
    Comparison. NOTE* Before you tell me I'm a dirty fuck, this came from a parts car.
    To put it back together just follow these instructions backwards. Make sure you dry the parts well, especially the pins where it gets plugged in BEFORE you plug it back into your car.
    Thanks for looking, and yes I do have too much time on my hands.
    Here's some LED information.
    Best bet is to get a pair of these and solder them in. Might have to modify the dome light housing so that these will fit. Best to measure first then order. Most of these LED boards have measurements on the page. eBay is your best bet. Pic is just for reference.
    Just cut it at the wires and solder em in. No need for that bulb adapter..
    Its what I did..
    This is my interior at night with the dome light on, no flash on the cam. *OLD PICTURE*
    05-02-2008
    Hacienda Heights, CA
    3,014
    nice tut. if i wasnt too lazy to take out my head liner i would deff do this
    01-19-2007
    Lyndhurst, NJ
    3,473
    You don't have to take out your headliner, you just have to take the dome light out of the headliner.. Lol, it pops right out..
    05-02-2008
    3,014
    hahaha, i misread!! ill try this on my next day off then lol
    hey do they make an led bulb for the dome light neone know??
    10-05-2008
    Grand Rapids Michigan
    1,141
    man that lense is nasty...mine are still perfect, but this is a good write up for people wanting to put LED dome bulbs in :)
    01-19-2007
    Lyndhurst, NJ
    3,473
    Updated first post with LED information.
    Quote Originally Posted by Jeffylou87 View Post
    which was my idea :-))))))
    How did you secure the led boards inside the housing so they don't flop around?
    10-05-2008
    1,141
    how are you illuminating your rear ?
    05-31-2005
    4,735
    thats effing bright.
    01-19-2007
    Lyndhurst, NJ
    3,473
    Quote Originally Posted by AmericanJambo View Post
    They just sit in there really.. They don't flop around at all.
    Quote Originally Posted by johnygezony View Post
    I'm using two 18'' LED light strips that are 3M'd to the top of the rear window.
    Quote Originally Posted by 9G View Post
    Yes it is. Just the way I like it.
    ohh man. I didnt believe your pic of the inside being that bright until I turned my dome lights on lastnight. It is amazing how bright it is. THANKS
    i have the same ones but dont understand how to put them in
    Where did yo get the 18'' LED light strips and howdid you wire them for when you open your doors?
    Experienced TGC Member SleekGTZ's Avatar
    05-09-2005
    Washington state
    1,065
    Awesome tutorial! My dome lights wiring contacts is probably dirty, sometimes they work, sometimes the don't, LOL. Haven't had time to fix it, maybe one of these days I will.
    How do you take it off from the roof of the car?
    04-08-2010
    Springfield, Mass
    1,225
    Just pull it till it pops off
    «Carlos»
    11-29-2009
    Chadds Ford, PA
    2,768
    stick a credit car inbetween it and the headliner and pry
    You can just grab it and pull it. Won't break.
Tags for this Thread
