Thread: 8G Dome Light Breakdown and Cleaning
Showing results 21 to 40 of 42
    ^I can't believe I said that. LOL!!
    12-13-2010
    Brooklyn, Maryland
    4,643
    You can just grab it and pull it. Won't break.
    I was gonna say, "that's what I told her..." lol!
    -Greg
    this will be next on my list of things to do,
    Awesome Jeff! I hate how dark the lights are and can't see crap inside + Painting options!
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
    Its easier to buy a rigid loop bulb and cut the light housing to fit it in. No need to solder anything.
    Took mine apart and it looked like a sand storm went through lol
    Member BayAreaGalant's Avatar
    03-13-2009
    Santa Clara, Cali4nia
    185
    I didn't like the yellowish color from the bulbs so I put leds in it but was too bright for me.
    So I used night shade to dim them.
    I couldn't be happier with the outcome.
    04-08-2010
    Springfield, Mass
    1,225
    You get more lighting if you install the 3g eclipse mirror
    «Carlos»
    antraw
    What type of bulb did u use for led?
    Sent from my Dell Streak 7 using Tapatalk
    02-08-2012
    Hackensack NJ
    1,146
    I was also wondering how you wired the led strips to illuminate the rear. I ordered some that are on the way and wanted to do the same thing but just didn't know how to wire them up and what switches to use. I'm thinking if you have to strips you just wire it up the the dome light of that side with no problems
    01-19-2007
    Lyndhurst, NJ
    3,473
    And you're exactly right.
    Just wanna add, if you have a factory rear dome light the bulb is a 31mm fetsoon bulb. I think only 8gs with sunroofs have a rear if read correctly. But when you replace it go ahead and disconnect the battery. I tried putting in my led replacement last night, and blew the top (facing front of car) fuse in the yellow holder. Its in the fuse box under the hood. Needle nose pliers are your friend for pulling it. Somehow I might've made contact with one bulb end and metal from the roof, and got a small spark. Its a small space to work the bulb in, so its easy to do. But all systems go today got fuse and bulb installed.
    I'll give the link later on to another thread I made on getting the bulb out, only thing that's not mentioned in it is, you push the bulb in on the left contact and slide out from the right contact..you'll see
    Edit..Link:
    https://www.thegalantcenter.org/showthread.php?t=49020
    02-08-2012
    Hackensack NJ
    1,146
    Quote Originally Posted by Jeffylou87 View Post
    Oh shit I'm smart lol. Well I'm guessing you fed the wires through the headliner. Am I right? If so how exactly did you do that? I really don't wanna take it off so I was thinking like cutting little holes and putting like a little weight at the end so it could be pulled down. So am I close?
    Also bro we should meet up sometime, you're only like 10 min away lol
    02-08-2012
    Hackensack NJ
    1,146
    This might sound retarded but I like your avatar of TGC NJ I was wondering if anyone had or can make that as a decal. I'd love to put it in my rear window
    New Member 89bri's Avatar
    03-01-2010
    Oregon, IL
    75
    Blog Entries
    4
    Alright people do this if you haven't done it. I took mine out about a month ago to clean them this way and wow. I thought they looked great before but you can't even imagine how great they will look after. Thank you for this tutorial!
    01-19-2007
    Lyndhurst, NJ
    3,473
    Damn this is old.. I ran the wire to feed the rear LED strips through the plastic moldings on the sides of the headliner. Each rear LED strip is connected to the correlating front LED. So if I click on the passengers side light, the rear passengers light turns on. etc etc.
    Got any pictures of how it turned out?? I am very curious of what it looks like
    1991 Jeep Comanche (SOLD)
    2002 Honda Accord EX (DAILY)
    1998 Eclipse GST (PROJECT)
    02-08-2012
    Hackensack NJ
    1,146
    You know what's funny is that I posted here over 3 years ago and I just did the rear lights like last week
  19. #39
    I wanna replace my dome lights with LEDs what kind of bulbs do i buy? (size)
    "Sometimes we win, sometimes we learn."
  20. #40
    Quote Originally Posted by trougtyr View Post
    Dome Light Bulb Size: DE3175
Tags for this Thread
