Thread: trans fluid
Showing results 1 to 11 of 11
    trans fluid
    what type of trans. fluid are you guys using?
    05-31-2005
    4,735
    oem.
    oem
    Amsoil universal. Have been using it since 10K, now transmission has about 170K. Usually, I change fluid every 15K or so, however, I have only changed the filter once. Never had to touch anything on the transmission and it's still going strong (knock on wood).
    Bronx NYC (reppin)
    3,489
    before 5spd was using oem
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
    12-17-2002
    Sherman Oaks, California
    4,304
    when i had an automatic, OEM
    for 5spd, BG SyncroShift II
    http://socallifestyle.com/
    1994 Galant GS 5spd
    can i buy oem at walmart?
    where do i get it and what do i ask for? not dextron or anything?
    Quote Originally Posted by Racer_S View Post
    No. Walmart has crap stuff
    OEM you can get it at a Mitsubishi Dealership.
    I paid $7.20 a quart. I bought 5q for now. I'm just going to drain and pour...
    Theres not many dealers around here. Is there an alternative I could pick up at a parts store? I think I might do the filter too. Its been shifting hard. The damage might already be done :(
    Yes, there is an alternative. If you suspect that your transmission is either low on fluid, or desperately needs a change (The A/T oil in this case has broken down into something that no longer lubricates), go to advance auto and tell them the make, model and year of your car. They've got some universal import A/T fluid that should work just fine. I've got it in my car now, have had it in for 10k miles now... Also get a filter and pan gasket kit.
    My car shifted REALLY bad when I first got it. Did a flush with advance auto fluid and that alleviated the majority of the rough shifting.
    I think it's Dextron III / Mercron III for imports if I'm not mistaken. Or you could just get the OEM SPIII diamond stuff like everyone else is saying
