Thread: Engine cleaning
Showing results 41 to 60 of 68
  1. #41
    Banned
    12-12-2009
    https://t.me/pump_upp
    154
    Can anybody confirm, Tire SHINE or Tire FOAM? Because of the description I would say its Tire FOAM but DOHC said Tiire Shine.
    None of them say aerosol. Anywhere else.
  2. #42
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    Quote Originally Posted by AktionCat View Post
    Wait what???
    My question is if its foam or tire shine, I would say its foam but I'm not sure.
    4g64T 5spd
  3. #43
    Banned
    12-12-2009
    154
    Wait what???
    He said it HAS to be aerosol. There's no aerosol product inside the tire foams.
  4. #44
    05-03-2007
    Socal/Central Coast
    3,803
    huhh?? Tire foam is the aerosol products. I used Armorall tire foam cleaner/shiner/whatever
  5. #45
    Banned
    12-12-2009
    154
    I figure any tire cleaner that foams will work as they all use the same sit and dry method.
    I'll grab some up this day..ended up going trail riding wif a friend yesterday.
  6. #46
    Banned
    12-12-2009
    154
    Have to use a toothbrush to get those other little splotches as even with high pressure water few inches away those still didn't go away :<
    Before
    Sprayed wif what seems to not want to foam up :<
    ArmorAll Extreme Tire Shine was all they had at the zone :/
    Drove from autozone to car wash about 2-3 miles. Then spray a bit more on. Waited a bit then started to wash.
    Mid Wash
    Used the high pressure but didn't squeeze trigger to do it except for those super stuck grime parts..which even then didn't work so well.
    After Wash
  7. #47
    06-13-2008
    Bronx, NY
    2,606
    Looks good. BUT is a no no with the ArmorAll Extreme Tire Shine. That thing is super Flammable. In autozone they sell engine detailer specially for the engine. Dont use that because it has a lots of oil residue. I got a good engine Degreaser can't remember the name but i got it on Autozone. Very good thing you spray it wait like 5 min and just wipe it off. It leaves your engine looking WET I mean WET. Preasure water or any kind of water is not recomended, because some electrical problem can accour also if you have a bad oil cap or gasket, "Water and Metal = RUST = Cancer for a car". AVOID AT ALL COST.
    SOHC Turbo
  8. #48
    Banned
    12-12-2009
    154
    Glad I pick the one not to use :<
  9. #49
    05-03-2007
    Socal/Central Coast
    3,803
    I think you'll be fine dude. The point is to get all of whatever you're using to clean the engine off by spraying it down. Isaurio, you're not supposed to wash down the bay and just let it dry, which actually could lead to rust. You spray down the bay, dry as much with a towel as possible, then go for a nice drive until the entire this has dried off.
    oh and about the flammability: all those aerosol products are super flammable. Personally I didn't spray the aerosol then go driving.. I simply sprayed it on then, let it sit, scrubbed a bit, rinsed, dried with a towel, then went for a nice drive.
  10. #50
    06-13-2008
    Bronx, NY
    2,606
    Yeah bro thats what i do. The special engine detailer says spray and let it sit for 10 min then clean it off with a towel and then let it sit with hood open for an 1hr. If you turn the engine on it will smoke all over. I'm saying that some people use that tired shine liquid to clean the engine and thats not recommended specially if you washed off with water. WATER AND OIL DON'T MIX. So the oil will stay on the engine. I will post soon a picture of the cleaner I use.
    SOHC Turbo
  11. #51
    05-03-2007
    Socal/Central Coast
    3,803
    correct water and oil don't mix, which is why you need a little bit of pressure in order to remove it. Much like washing oily dishes. If you have enough water pressure, most of the oil on the dish will wash off, and this is simply with a sink facet. Put the correct nozzle on the garden hose and the stuff comes right off.
    this is what I used:
  12. #52
    05-03-2009
    1,465
    I think DOHC meant tire foam then lol
    4g64T 5spd
  13. #53
    06-13-2008
    Bronx, NY
    2,606
    Water pressure is not good for the engine wires and parts. Is my opinion. If it works for you hey!
    SOHC Turbo
  14. #54
    Banned
    12-12-2009
    154
    It's not good cuz the pressure can easily get into the wire harnesses..Hence why I don't pull the trigger..I know there's a tire shine that foams and actually stays foamed for awhile but the AZ I went to was crap on tire foams as compared to most other AZs i goto.
  15. #55
    06-13-2008
    Bronx, NY
    2,606
    Ok. Here what i use.
    Here is the link for better explenation:
    http://www.detailingtricks.com/2009/...gine-detailer/\
    Example of engine.
    Before:
    After:
    SOHC Turbo
  16. #56
    04-08-2010
    Springfield, Mass
    1,225
    My engine is always clean but what I use is simple green nothing else... works great spray it on wait a few and power wash the engine while its on never had any electrical problems or anything then after that I spray tire shine and leaves the engine nice and detailed
  17. #57
    07-12-2007
    SoCal
    4,632
    Thats dope if that actually works like that. Im gonna try it out...
    JDM Zenki Conversion
  18. #58
    05-03-2007
    Socal/Central Coast
    3,803
    hmm I feel like they had to do a little bit more than just spray that stuff on.. but how much did it cost you?
  19. #59
    05-02-2008
    Hacienda Heights, CA
    3,014
    yeah, you need it
  20. #60
    06-13-2008
    Bronx, NY
    2,606
    In autozone is like 5 dollars or something like that.
    1.Spray
    2.bruch
    3.wipe
    4.Spray gain
    5.Wipe again
    6.let it air dry for 1hr
    7.turn on engine for 15 min.
    Done.
    SOHC Turbo
