Thread: Tire Size Problem/Question
Showing results 1 to 5 of 5
    Ok..i went over the proper tire size sticky and im kinda not sure bout it. I jus a got a set of 215/55r17 for my new 17"s comin and Im not sure if everythings gonna clear..i'm guessing it will but could someone say For sure??
    Experienced TGC Member rez887's Avatar
    06-10-2005
    Dallas
    1,236
    It depends on the width of your wheels.
    The Rims are like..7"
    01-08-2008
    Levittown NY
    2,786
    They should clear width wise unless your offset is like 35 or lower, but you got the wrong size completely. 215/55-17 is 4.2in more in circumference then 195/65-15 which is stock. I have 225/45-17 which is the exact same circumference as stock.
    Quote Originally Posted by The_fresh_Galant View Post
    I DID say for sure. That is why I made it a sticky. I didn't just pull the information out of thin air and just post it. Read the sticky, stick to the sizes and information given, and you won't have anything to worry about.
