my bad, just saw another post about the same thing
hey guys, just wondering if the 95-99 eclipse tanabe rear underbarce is compatable with the 7g chassis more specifically the vr4
need it because iv exceded the amount of power the chassis can handle and its skating all over the place on boost
cheers
You'd be better to look for one compatible with the 8G VR-4, as the chassis is virtually identical to the 7G VR-4.
1995 FTO - V6 Mivec 200hp
Do you have a 1 piece coilover type suspension? You could dial in some of the settings to help "control" the car.
Also along with the underbrace...have you upgraded your front and rear sway bars?
to add to Kevin's post....
Are you still running all of the factory rubber bushings?
