Thread: Turbo question for you gurus
Showing results 1 to 11 of 11
    12-27-2005
    Charleston SC
    1,520
    So... In my quest of doing my turbo build ive come into a bind. I dont have room for intake piping on my setup. My question is will it hurt to install a filter directly at the turbo? Its a 16g turbo, i have the upper portion of the heat shield for the exhaust, i have a 27x7x2.5 FMIC and ill be running the GM maf setup so there isnt any need for the maf to connect to an intake. Im at a loss and it seems that my only option is ordering a K&N filter from their web site. I have like 4 inches of room to work with. If anyone needs pics to help with your suggestions ill get some tomorrow.
    Thanks in advance,
    Johnas
    08-13-2008
    Waterbury, CT
    3,331
    if ur running a MAFT setup then u can put a filter directly on the turbo intlet
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    12-27-2005
    Charleston SC
    1,520
    My only dilemma is that i read where the heat will effect it. I think its BS though because the intercooler is supposed to do its job PLUS the J-Pipe is in the line of heat along with the compressor side of the turbo... IDK... No offense but i want more opinions. Though im leaning on the it doesnt matter side... Thanks dude!
    As long as it is a quality filter, you shouldnt have issues. I know John runs a filter directly on the turbo and a lot of DSM people do the same. I wouldn't think the heat would be significantly different from a stock maf setup.
    Quote Originally Posted by seth98esT View Post
    Lol to tell the truth, I haven't run a filter at all in 2 or 3 years.
    Just open turbo. Turbo still looks and performs perfect.
    I imagine if I took to the time to make an intake for it though I would see better performance and mileage. Especially in traffic where airflow under the hood is minimal
    i have seen members run with no problems. laxin warrior used to run just a mesh screen over the turbo. as long as you dont need the MAS, and have the translator your fine
    wow, brave!
    wow, brave!
    I'm not recommending it. Lol something tells me that if I pull the pipe off my intercooler inlet there is going to be a rat's nest of grass clippings and insects.
    My compressor wheel is still pretty though. Even with the compressor housing off.
    I ran w/o filter for good 4 months before i put the intake pipe. The lower rad hose is like 1mm away from the intake pipe
    12-27-2005
    Charleston SC
    1,520
    I think i can get the 2g radiator hose to fit. I have a spare from my gfs car and with a little nip and tuck it will work. Of coarse im going to get a brand new one because there is an obvious reason it wasnt put back on her car. LOL. Anyways. Im going with a 5x4x2 1/4 filter from K&N. I talked to the lady and she said it will flow over 400 CFM and thats a good bit. Im running the small 16g so i dont think it will be a problem.
    12-17-2002
    Sherman Oaks, California
    4,304
    i wouldn't be that scared if you're only reason to fear is the ambient heat; there's still a lot of pipe for all that air to travel, and the fmic should pull it's weight
    http://socallifestyle.com/
    1994 Galant GS 5spd
