Do These HID's Fit?
hey guys i got my hands on some 2002 maxima HIDs just wondering if they would fit and if they are worth putting in.
you can make anything "fit", but the US spec 8G headlights are H4 dual filament bulbs so you will lose your high beam since the nissan 2002 maxima housings are dual bulb using one pair of bulbs for high and one pair for low (like 8G JDM's incidentally). also unless you make sure that the capsule position of the maxima D2S bulb is exactly where the H4 low beam filament would be, the beam focus may be off.
now if ur talking about converting the 8G to full maxima HID housings, that sounds like a very cool idea but it will run you a few grand for a clean install.
again, w/ enough money, research and good execution, anything is possible.
