should be on top, or maybe bottom, on the right or left side of the engine, by the timeing belt. before you buy a new 1 make sure the one in there still works. it could just be out of wack and seting a code. take it out, clean it, put it back in better. if you aint got a misfire it should be straight. that gap between the sensor and rotor must be set correctly.
