Quote Originally Posted by Dominicano View Post
if you tap into the two ground points on the steering column for left and right and run the power of somewhere else fused of course wouldn't that basically do the same thing without needing a relay or any other stuff. i found the connector and the pin position on the 8g manual
You would be correct, however I don't recommend you do that since the trigger points are such small gauge, it would be best to go with the relay and prevent a fire hazard.
