Thread: 5 speed swappers...help
Showing results 1 to 20 of 26
    North Bay...NorCal
    2,552
    Quick question...any of you have the reverse lights come on when you put the car in reverse? I just got my reverse sensor from Bronxbomr (Thanx Al) and I am pretty sure I know where on the trans the thing goes. My problem is the connector that clicks in the back....I dont seem to have the right one or one at all. Anyone have any pics? Or do I have to swap the one from the auto (splice wires) and put on a 5 spd connector?
    08-15-2006
    Perth Amboy, NJ
    1,558
    i still have to setup my reverse lights. Mine don't work either
    run1206's Rear Disc Tutorial
    Proto
    The reverse sensors are a different length if I recall correctly but make sure you spliced the correct wires in the harness first.
    12-27-2005
    Charleston SC
    1,520
    Youll surely have to splice the wires... If i call correctly in a thread i read from somewhere it said the green and white wire were the ones.. IDK it will take a very long time to search for that too.
    North Bay...NorCal
    2,552
    yeah I am gonna have to try that ^^^ when he and I did my swap I didnt have the sensor. Now I actually need it! LOL
    05-03-2007
    Socal/Central Coast
    3,803
    If it's similar to the 8G 5 speed swap, you're gonna have to splice some wires. I used some old connectors I had sitting around and spliced one end into the car harness, and the other to the reverse solenoid, so that I could easily unplug it whenever needed
    Oh boy its been a while... but i do recall splicing the wires.
    Bronx NYC (reppin)
    3,489
    u have to splice the wires
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
    ill post up the wiring diagram when i get home.
    Cali: Sig 3/28/2011
    North Bay...NorCal
    2,552
    Thanx for the info guys! The help is much appreciated
    they were two red wires on the big plug from the auto tranny harness
    North Bay...NorCal
    2,552
    ^^^ok....and? Did they look different? Couldnt have been just 2 red wires...was it red with white stripes, red with green? So the big ass plug I have is the one from the auto trans....thats the one I gotta rip apart? Cool
    have fun
    10-18-2007
    Glen Burnie, MD
    1,314
    Lol I haven't hooked mine up either
    TGC Regular eclipsh's Avatar
    09-06-2008
    SW Colorado, USA @ 7600 ft
    533
    After a few months of driving my 7g around I found out my brake lights came on every time I hit the clutch pedal or the brakes. Be sure to check that out too.
    North Bay...NorCal
    2,552
    ^^Nah...all my lights work properly...I just have no reverse lights thats all
    12-17-2002
    Sherman Oaks, California
    4,304
    it's the last picture at the very botton of my 5spd swap tutorial:
    http://socallifestyle.com/tutorial/tutorial.html
    you can splice or you can get some spade connectors for each wire so it can be unplugged in a pinch
    1994 Galant GS 5spd
    North Bay...NorCal
    2,552
    I have some connectors. I am just gonna cut the wires and crimp em into the connectors and plug em in. I dont need the plug from the auto anymore so...
    Thanx guys! I'll keep yall posted
    North Bay...NorCal
    2,552
    anyone have a pic of where on the top of the 5spd trans where the sensor goes? nwhere I think it goes...the bolt wont move so...
