clear silicone or glue
Back in september, when I got in my accident, my left tail light got cracked, but I didn't bother ordering a new one because it wasn't too bad and I was on a budget (16 with no job at the time.. y'know.)
Today I washed my car and noticed that the light FILLED to the top with water. I let it all out and drilled a hole in the bottom in case it happens again, but I'd like to fix the crack.
I'm not sure how well the picture shows this, but there crack causes about a 3-4mm space where water can just gush in.
I'm wondering if I could try and use a lighter to melt the plastic back together? I'm getting new tails sometime soon, but until then, I'd like to have this sealed as best as possible.
1999 Mitsubishi Galant ES
dude you can get that taillight for under 20 bucks on ebay!
Clear silicone!
If you're looking for a set i can get you both for $60 shipped. If you can't find anything on ebay that is. Pm me if you're interested
Eclipse GT 5 spd swapped
Rotor Glow Galant
Daily Galant
OZ Edition Eclipse
I ended up breaking out the heat gun. I pushed the knobby end of a screw driver through the reverse light hole, and pushed while i slowly heated the plastic. It got the job done. Doesn't look perfect, but it actually does hide a lot of the crack - you can still tell it was cracked at one point though.
Thanks all for your advice!
keith - I might take you up on that in the future if the offer still stands; It would be good to have another set on hand in case another crazy girl decides to rear end me!
