Thread: NGK Wire set only has 2 not 4 ??
Showing results 1 to 5 of 5
    I've read on the forums that NGK Plugs and wires are the best for Galants and I've looked into replacing my dying plugs and wires with a full set of NGK.
    In looking online all the boxes and images only show the 2 of the 4 wires needed. It appears as if they only supply the ones with the knob attachments and not the 2 with the coil attachments.
    Can someone explain this to me? Can you only buy the one set, where do you get the others?
    My set of NGK plug wires has all four in the box..but then again mine is for a 7g which has a distributor. I don't know squat about the 8g set up.
    02-07-2007
    ORLANDO
    1,599
    Quote Originally Posted by BladeX975 View Post
    theres only 2 wires...that come off 2 coil packs...coil packs have boots too which you can buy at the dealer
    Quote Originally Posted by 02redgalant View Post
    Thanks!
    NEWBIE
    02-11-2010
    Fort Wayne, Indiana
    11
    The boots that attach directly to the coil rarely go bad though. It's a direct link. No wires to corrode.
    Go B4 Sho
