Thread: 5 speed swap
Showing results 1 to 15 of 15
    TGC Regular bsilver23's Avatar
    04-06-2009
    Mequon, Wisconsin
    584
    5 speed swap
    I really want to do the swap, but i feel that i am not capable of doing it myself. Would it be a good idea to take it somewhere and have it possibly done if they think they can do it or is that not a good idea?
    Bryan - TGCWI - 6g72 5 speed
    http://www.cardomain.com/ride/3376567
    11-29-2009
    Chadds Ford, PA
    2,768
    i dont think a shop would do is due to there being no clutch safty mechanism, i would try to see if there are any memebers in your area willing to help you out
    04-06-2009
    Mequon, Wisconsin
    584
    thats kinda what i figured
    04-10-2005
    NYC
    3,695
    you would have to hook up the clutch saftey...most of us just choose not to...that has nothing to do with it...although to the OP im sure that you are prob more capable then you think...there are a few guys around your area that im sure would have no problem helping you...im sure a shop in general would be expensive...but if thats what you ultimately want to do it doesnt hurt to check around with some of them...
    01-19-2007
    Lyndhurst, NJ
    3,473
    I had a friend help me out.. A friend with a shop and the knowhow..
    04-06-2009
    Mequon, Wisconsin
    584
    i mean, i really just need someone with the proper equipment to help me out and it would be pretty simple i think.
    11-29-2009
    Chadds Ford, PA
    2,768
    if i was up in wisconsion id help you, i think blue8g lives up there, he got a 48 hour bann so when he gets back i would shoot him a pm. Sorry if off topic, but is there anything for wiring up a cltuch saftey??
    Bronx NYC (reppin)
    3,489
    if you have all the right parts, plane ticket, room and board then im there.
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
    I did my swap on the floor in my garage while still being able to park another car inside at night. You need your basic hand tools, a clutch alignment tool, jack stands, 2 or more jacks and a torque wrench. Thats honestly all I used.
    Jigz-TGCIL Sosick Motorsports
    And its doable in less than 12 hrs. Ask Bronxbomr
    04-06-2009
    Mequon, Wisconsin
    584
    wow ok i guess i just need to be creative to make it happen ha
    05-03-2007
    Socal/Central Coast
    3,803
    Yea my tools list is pretty similar to Jigz's
    Tools:
    4 jack stands (2 to hold car up, 2 for engine support)
    Ratchets, Sockets
    Torque Wrench
    Breaker Bar (big!)
    Clutch alignment tool (usually comes with a new clutch kit)
    Car Jack
    Wood Blocks (for raising up the car jack.. I know.. pretty bad bahaha)
    Engine Hoist (not totally necessary, but it sure helped me a lot)
    Ropes (to lift up the 5 speed using the engine hoist)
    how did you assembly the clutch pedal and shifter
    TGC Regular Boosted's Avatar
    12-03-2008
    Fayetteville, NC
    575
    As far as the jack stands and jack are considered, I wouldn't do it. It is a feasable method but I would rather use a lift.
    11-29-2009
    Chadds Ford, PA
    2,768
    Quote Originally Posted by Lethalwx69 View Post
    everything bolts in where it would belong, the MT shifter mounts ar in the same location as the AT. The clutch mounting holes are there just need to be drilled, look under the dash where your brake pedal is mounted, to the left of that is an squarish outline cut in the sound deadening, if you pull that out you will see where you have to mount the clutch all you need to do is drill and dremmel out that section
