NEWBIE
sunroof
2003 galant es
roof opened and won't close
is this a factory or aftermarket roof?
it's a black switch [white & black arrows] in the headliner above the lights
if aftermarket how do i find out the installer?
is it the same everywhere or someone special where i bought the car in nj
New Member
Sounds like factory, did you check the fuse?
does it attempt to close or make any noise at all?
NEWBIE
sunroof
opened roof
when i went to close it,it went to the close position but reopened
happened a couple of times
only way to get it closed was to disconnect then reconnect switch
is there some type of control module?
will not mess with it again until the weather gets better
