Thread: Aftermarket Subs! PLEASE HELP!!!!
Showing results 1 to 6 of 6
    airplane_mechanic09
    Icon10 Aftermarket Subs! PLEASE HELP!!!!
    hey, I have a 2002 Mitsubishi Galant. I would like to add an aftermarket sub into my stereo. I am still using the factory Infinity stereo system. The Model number on the amplifier is MR238958. How do I wire a sub into the existing reciever? Thanks
    04-10-2005
    NYC
    3,695
    if you want to add a sub into the stock radio you will need a line out converter...it allows rca's to be spliced into the stock wring.
    heres a link
    http://www.crutchfield.com/g_721/Lin...s.html?tp=2001
    airplane_mechanic09
    Do you know how I would wire it in? Such as which wires on the line out converter go to which wires on the cable coming from the stereo to the amp?
    04-10-2005
    NYC
    3,695
    it should be labeled as to what you need to wire it to. then you would wire up your amp as per normal and plug the rca's into the line out. for the remote wire, you could tap into the cig lighter power wire since it cuts off when the car is off
    You have to buy an aftermarket amplifier to power your subwoofer. You then have to wire A "Line output converter" to the speaker outputs from your factory amplifier to convert a signal to RCA. You have to connect a power wire to the battery with a fuse near the battery and a ground to chassis ground. You will have find out what size wire to run also, 8,4,2 or zero gauge depending on the size of the amplifier you use. You will also need to run a remote turn on lead power that turns on with the key, you can find that behind the radio or at the ignition harness.
    Sign here so we can do stuff to your stuff...
    New Member OhNoItsFelix's Avatar
    09-09-2010
    Fresno/Modesto, California
    80
    Best recommendation is to buy an aftermarket amp. The stock amp isn't going to output enough power to give good sound on the subs. Best solution is to get an aftermarket amp and have only the subs wired to it. It's how I did mine.
