Thread: backwards maf translator
Showing results 1 to 3 of 3
    Member allrice4g64's Avatar
    02-08-2010
    hager city, wisconsin
    330
    so as i was logging and tuning tday i encountered a wierd problem with my maf translator. as the manual states you turn counter clockwise to richen and clockwise to lean. well my aux and base work like that but then when i was tuning and adjusting the idle mid and wot it was all backwards i turn the dial counter clock wise on the idle nob and it leans it out. same with mid and wot. but the aux and base work normal like they should. anybody ever have this prob?
    no its not.
    it says it in the manual:
    BASE knob only - clockwise = leaner; counter clockwise = richer
    IDLE, MID and WOT knobs - clockwise = richer; counter clockwise = leaner
    02-08-2010
    330
    ok i printed the manual offline i must of not read it carefully enough or it didnt print that part. thanks for the help glad its working fine.
