Thread: Fender Rolling
Showing results 1 to 20 of 24
    Fender Rolling
    I did see the baseball method and everything. I just thought i would share this with everyone if the instructions were not clear enough. I'm going to try this suggestion as this persons method is a little different than anything else i have read so far.
    Quote Originally Posted by gandolf the white @ audiworld.com
    searched aw and compiled everyone's idea realized if theres a 100 ways to do this then it can't be that hard...so home i go last night go dig threw the garage find me a 2 and half foot piece of 2 inch black ABS pipe, heater/hairdryer, and get the floor jack (you can use the factory jack here as you are not lifting car off ground. Using no cloth as plastic doesn't do anything to paint. Raise my car so i can get pipe between fender...heat fender..lower car a bit...roll...lower...heat again...more roll...
    THEN i found the secret: by making edge of pipe even with edge of fender lip you can roll the lip as flat as the rear...no fender liner trimming required it tucks up behind lip after it gets warm. (you can heat fender liner to mold even further away but i didn't find this necessary)
    No pics but some quick drawings.
    Believe me never did this before and it really was easy and looks perfect.
    Source and pictures at:
    http://forums.audiworld.com/showthread.php?t=1540667
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
    does this method warp the paint on the outside of the fender??
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    Quote Originally Posted by Fresh_617 View Post
    Thats why you use the hair dryer/heatgun, to protect the paint making it flexible. In the tut he doesn't heat the outside of the fender but I think is needed or you'll end up F**ing your paint.
    4g64T 5spd
    u have to heat the outside or just the part ur trying 2 bend? im not trying to warp the paint or anything also not to sound retarted but where can i find a 2" abs plastic pipe???
    05-03-2009
    1,465
    I would say both to your first question, and try finding the pipe at a hardware store.
    4g64T 5spd
    i think this particular piping he's using is just basically drain piping. Meaning you can get a piece of PVC piping or probably get a piece of electrical conduit piping. I believe all of these share almost the same properties.
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
    but the impression im under is that he used that pipe bcuz it wont bend but yet bcuz of the material it wont damage the car is this correct?
    i have a fender roller available if you'd like to rent it. PM me.
    Cali: Sig 3/28/2011
    Yes this is correct. the pipe is basically strong plastic. You still have to be careful when you do it, but yea.
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
    Quote Originally Posted by Cali View Post
    How much is it to rent a roller from you?
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
    very good question and how do u use it? is it simlar to the method above ?
    if you're talking about the roller. I believe it bolts to the wheel bearing? I also think it has a jack like system to add more pressure to the fender as its being heated up.
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
    does it provide heat 2 the area as its rolling as well? and also i noticed that the method above was done on a audi, does that apply to our cars 2 i noticed that there are 2 peices to our 8g fenders and there fairly thick how do we "roll it" when that lip...dont really kno what to call the area...extends thru the whole wheel well? we have to bend the whole area or just a certin part"
    05-03-2009
    1,465
    This video shows you a Eastwood fender roller VV
    http://www.youtube.com/watch?v=PqiTfYyaI1A
    4g64T 5spd
    ah i see very interesting very interesting that helped alot thanks i will try to find some plastic pipe 2morrow lol
    03-12-2007
    Dallas TEXAS
    2,041
    cut dem shitz out
    cut dem shitz out
    I would but our fenders have important welds that keep the inner and outer fenders together. I know people have done it. But especially for me, its not a good idea.
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
    when r u gonna try? im lookin 4 the pipe and ima give it a shot...even tho on that forum they were using a audi it should still be pratically the same right?
    05-02-2008
    Hacienda Heights, CA
    3,014
    cut dem shitz out
    yup =]
    03-12-2007
    Dallas TEXAS
    2,041
    ok maybe not lol im sure you northern guys have hell with rust as it is dont need any separated raw metal. but im in dry ass Texas... dem shitz got cut yoe. i rolled them with the PVC method first wasnt enough so i got jiggy
Tags for this Thread
