Thread: rim problem???
Showing results 1 to 17 of 17
    rim problem???
    i just install my rim like a month ago and since then i always drive slow just the speed limit,,and last night i went to tgc meet and i go like 80 mph and my steering wheel become shaking i dont know y and when i slow down there is no more shaking,,,i never have prob with this before with my stock rim,,
    by the way i have 17x7 rim and 225/45/17 tires
    05-02-2008
    Hacienda Heights, CA
    3,014
    get your tires balanced. that's most likely it
    rocgalant
    Yeah what he said.
    05-31-2005
    4,735
    yap
    how much do you guys think the balance will cost me??
    rocgalant
    A generic Pep Boys type spot use computerized alignment which would be around $70. The good news is those type places usually have a coupon you can print online. I would say to rotate your wheels (if you haven't done so in a few thousand miles), then go to the shop. that way, you're tires (tread wear) and wheels (alignment) are good
    balancing at my job (sears auto center) is about $13 per tire
    Quote Originally Posted by rocgalant View Post
    no mah tires and rims is only a month old,,i dont know y its doing that shaking thing when i go more than 80 mph
    sounds like you need some hubcentric rings or your wheels rebalanced.
    yep getting balanced should solve ya problems
    Quote Originally Posted by pinoyesv6 View Post
    sorry for too much question.. what is hubcentric rim???is it hard to install???thank you so much
    4,455
    these are hubcentric rings
    they basically go in the center of the wheel where the wheel goes onto the bub of your car. You just need the right diameter and thickness to solve your problem
    http://www.justforwheels.com/index.j...entric&sub=how
    Jason - - cofounder of TGCNY
    2001 Galant ES
    Quote Originally Posted by mrjaydeeone View Post
    thank you so much sir..
    01-08-2008
    Levittown NY
    2,786
    I will x2 on these my Konigs did the same thing around 60 before I got rings now its smooth.
    The reason for hubcentric rings is because you have after market rims they are made to fit the hubs of most cars out there on the market so when you install them without the rings you make them lug centric hoping that the wheel is balanced correctly. That is rarely the case the hub centric rings will allow you to have the rims sit on the hub so that when you put the lugs in the wheel is already centered and balanced.
    if i dont have that hub centric ring for a month coz i just notice,,,im i damaging my rim or my hub???
    my old rims did this but it was because of a bubble on my sidewall of one of the tires. Rode smooth slow but when I went faster it shook like crazy.
    11-18-2009
    Buffalo, NY
    1,758
    my whole front end shakes when i drive fast but i think its my tires
    - Chris -
    DRL Delete
