Thread: motor question
Showing results 1 to 13 of 13
    motor question
    i found this motor in the self junkard auto part here is the picture it came of a 96 galant automatic and there it is and over there all the motors are 200 dollar and low milieage [IMG][/IMG is that a gs motor
    Yes. Any stock DOHC 7G will be a GS.
    so is it good to get it for 200
    Member allrice4g64's Avatar
    02-08-2010
    hager city, wisconsin
    330
    ya thats a good deal but its in a junkyard for a reason. i wouldnt plan on pulling the whole motor and just droping it in your g and expect it to work.
    yeah i know but i can just check there
    04-25-2007
    727
    Thats a really good deal!!! You should get it, rebuild it and boost it at the same time....
    ill take the shifter linkage out of that car, the shifter bezle, the coil transistor plug, and the valve cover..... THNX
    1996 galant s
    this is not a 96 galant. that means even if you get wiring harness and ecu it may work for you but it will fail emissions cuz its obd1
    emissions are for pussies...... (i have not done emissions since 2004)
    1996 galant s
    well they is this one and there is a gst motor for 200 with the small turbo
    08-13-2008
    Waterbury, CT
    3,331
    thats def a 94 gs and its a 5 spd u can see the slave in the top right of the pic. id pick up that motor to build and for 200 its a good deal as just my 2g cylinder head was 150.
    pick it up, rebuild it or fully build it, then boost it. do the 2g ecu swap and then your set. dont change harnesses as your OBDII
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    if thats a gs, if it were me, ide grab the motor, harness, ecu, trans, sway bar, disks, and anything else you can get your hands on. its easyer and quicker to swap the motor and get it running untill you get the harness figured out. but thats just me.
    1994 Galant S. 90 Percent GS.
    dont worry i get that the only one in houston
