Thread: alarm went crazy when trying to program remote, Help!!!!
Showing results 1 to 6 of 6
    I was trying to program a remote for my galant. I was using a paper clip to jump 1 and 4 together. well i jumped the wrong ones and now my cars horn went off!! i cant get it to stop. well i disconected the battery. and then my horn. and when i try and put the battery back, my emergency lights are on, and im gessing the horn should be on aswell..
    My power locks arent working aswell. and the hazzards stay on like city lights... no blinking or anything like that.
    Is there anything i should do to stop this? is there a button i should push or a sequence?
    Thanks...
    and to clarify, i dont have an aftermarket alarm. i dont think i have an alarm period... just a keyless entry sytem from factory.. thats what i was trying to program...
    Any help would be greatly appreciated.
    02 Red Galant ES- The usual
    04-29-2009
    Holyoke,Massachusettes
    3,600
    my suggestion is go 2 the dealer and have them reprogram it for you its your best bet
    Quote Originally Posted by Corey2000Galant View Post
    I think the etacs is fried or it shorted out.... does anyone know it it can be opened and checked out? where can i find a etacs ecu for a 2003 galant es?
    fixed.... i replaced the etacs module and it solved the problem...
    Thanks for all the help i didnt get.
    01-19-2007
    Lyndhurst, NJ
    3,473
    Quote Originally Posted by ramon64124 View Post
    You probably would have gotten a few more responses if you told people what pins you were referring to. Pin 1 and 4 on what? After the fact, I now know you were talking about the ETACS.
    Thanks man.
