Thread: Alternator tutorial?
Showing results 1 to 11 of 11
    09-10-2003
    Charlotte, NC
    4,463
    Gonna try to save some loot and replace my alty on my own, would like a tutorial specific for an 8G rather than the generic ones I am reading online if available. Thanks in advance, any pix avail would be cool too
    09-10-2003
    Charlotte, NC
    4,463
    dang
    05-03-2007
    Socal/Central Coast
    3,803
    V6 or I4?
    edit: never mind I just went to your garage and saw you have an I4. Let me check out the FSM
    okay it doesn't look too hard. It appears that you have to loosen your drive belt first (PS and AC) which only requires loosening 2 bolts on the tensioner pulley. Then once you remove that you have access to the belt for the alternator. Take that off, then you can remove the alternator by removing its 2 mounting bolts.
    At least it appears that simple.
    take off the negative terminal FIRSTTTTT
    loosen the tension on the belt
    remove belt from pulley and let it hang
    remove the 'tensioner' which is just two bolts in a little block
    remove the lower swivel bolt
    and remove the alt.
    i think u gotta take it out the top and bend your ac lines out of the way a bit.
    then reverse that for installation. i had a few alt issues with the high outputs and took out and put in a diff alt like 5 times in a day....
    02-28-2005
    Metropolis
    3,540
    I did one about changing the drive belts if you follow that you can adapt it to take off the alty.
    Quote Originally Posted by SkylineG1 View Post
    https://www.thegalantcenter.org/show...ht=drive+belts
    2001 5 speed 4g64T
    09-10-2003
    Charlotte, NC
    4,463
    k attempting this today.. for clarification
    One of the steps is loosening the tension on the belt.. do I do that from here?
    Don't need to touch any of these right?
    the used alty has some cut wires on the other side of the harness.. ???
    Anyone recommend a breaker bar or should be able to get by without one?
    Experienced TGC Member Bloody Arro's Avatar
    04-14-2009
    Highlands, Tx
    1,066
    I'd bring a breaker bar just in case. When I changed the alternator in my 02 I needed one, but that could be just because the owner before me power housed over-tightening on EVERYTHING he did..
    And fwd grocery fetters are fun, you wouldn't be on this forum if you didn't agree
    Quote Originally Posted by 8thLS6 View Post
    Tuning to me is like magic... I don't understand it but it makes things happen lol
    You can lead a horse to water, but you still can't make it drink...
    01-08-2008
    Levittown NY
    2,786
    One bit I will tell you is if you are looking for a slightly stronger alternator you can use OEM 2004-2005 3G ones. They are 95 amps compared to our 85amps and I believe 1 dollar more or there abouts.
    Quote Originally Posted by 03-Galant-ES View Post
    Thank you for this.
