Thread: Went to wire up the speedo...
Page 5 of 10 FirstFirst 123456789 ... LastLast
Showing results 81 to 100 of 195
  1. #81
    08-04-2003
    NY
    4,344
    Ok so thats one theory down. I had looked at some diagrams from the 3g eclipse and they have a split like we do, 00-02 is one style fuse box/external vss and then 03-05 is the other style fuse box and internal vss. On the 03-05 3g, the speed sensor lead wire going to the ecu/cluster is supposed to be white with a blue stripe, so I wanted to see if our harness' shared that same wire but apparently they dont
    Can someone confirm this for me, where does connector C17 plug into? Does it plug into the fuse box under the dash near the ETACS ECU? I havent had that stuff apart in a while and I dont feel like pulling all back apart.
    99' Galant ES
    4G64/63T
    AEM EMS
  2. #82
    are you talking about where you disconnect c17? or are you talking about where the male side goes into the dash more?
  3. #83
    08-04-2003
    NY
    4,344
    Quote Originally Posted by galantman03 View Post
    Im talking about what does C17 plug into? Does it plug into another harness? if so, where does that go to? If it goes into some type of module or computer, which one? got good pics?
    99' Galant ES
    4G64/63T
    AEM EMS
  4. #84
    Ill have to look sometime in the next week... Today is just to dam cold out lol
  5. #85
    So I looked at it, c-17 connects by your feet, and then goes up on the inside of the dash, right beside your leg, behind the cluster and then down into the ecu
  6. #86
    08-04-2003
    NY
    4,344
    Which leg? Left leg? Which ECU the ETACS?
    99' Galant ES
    4G64/63T
    AEM EMS
  7. #87
    c-17 goes from your right leg, up and over behind the cluster, to your left leg and into the ETACS ECU
  8. #88
    BUMP any word on this? I'm thinking really hard about the harness swap haha
  9. #89
    12-02-2008
    Carteret & Manalapan, NJ
    1,263
    Yeah I deff need some info, I cant figure out what to do...bad enough I really suck at wiring but this is making my brain melt.lol I can't swap to an older Harness bc I already wired up injectors and a shit of other stuff and reaaaalllyyyy dont feel like doing it again.
  10. #90
    anything happen on this? I did some metering on the pins and what not last night, and I'm still up in the air, do we know for a fact that the auto input and output speed sensors are the same signal as the speedo in the eclipse manual speed sensor? Are people in the eclipse scene that have swap from auto to manual having this same issue?
  11. #91
    08-15-2006
    Perth Amboy, NJ
    1,558
    i'll have to check up on the eclipse harness and it's connections. I haven't been working on the wires or anything just yet, will try to check it out again sometime next week.
    run1206's Rear Disc Tutorial
  12. #92
    10-18-2007
    Glen Burnie, MD
    1,314
    Im gonna try the way you originally did it drew. First I want to pick up a new speed sensor
  13. #93
    08-15-2006
    Perth Amboy, NJ
    1,558
    No problem. I'll try different wires now that i'm under 1/2 tank.
    I guess the voltage for one of the wires goes up as the fuel tank level goes down until the fuel light goes on. All I need is a 'power wire' to keep a high enough voltage to measure the speed. Just found my manual papers too, thankfully.
  14. #94
    Here's a thought, it came to me in a dream so bear with me lol. If vss system uses the hall effect, then there is a power wire to the transistor in the sensor, and everytime it picks up the magnet it sends a pulse. I'm thinking its a square wave pulse, it can't be a voltage because the faster the pulse the faster you go on the speedo. So Im willing to bet that the vss sends pulses to an ecu wether it be the ETACS or the pcm or the actual ecu, and then gets translated into a voltage output and gets outputed to the gauge cluster. So I'm going to meter into the vss input and output plugs and see what plug It goes into and vice versa. Basically I'm looking for the one wire that's sends the VOLTAGE to the cluster, and then tap the signal wire from the eclipse speed sensor into that. What you think?
  15. #95
    12-02-2008
    1,263
    I think that is a pretty crazy dream you got going on. Do you usually dream things like this?lol
  16. #96
    Dude you have no idea lol, I deal with stuff like this at work and when I can't figure something out on the jet, Ill have a dream or something, Idk what it is, but than usually I can figure it out lol
  17. #97
    thats pretty crazy,maybe you will figure out the problem with the wiring and then the guys with the newer galants will have no issues with doing the 5 speed swap.
  18. #98
    ^ hopefully we can figure this thing out. I can't stand not having a speedo anymore, its driving me crazy.
    Does anybody know where the pcm is located? is it apart of the etacs ecu? also, where is the picture that locates all the connectors in the vehicle?
    You were just looking at it backwards, you were assuming wire position based on looking at the connector from the wire side head-on, when the FSM displays them as if you were looking into the end of the connector at the pin side. Hope this works out.
    is it looking at inside on the MALE side? or female side? I wish on the connectors they would tell us whats what. At least have 2 pins labled lol
  19. #99
    08-15-2006
    Perth Amboy, NJ
    1,558
    I'm under the dash right at this moment. The current wires I have are like this...
    The red and green wires are what I'm using to connect to the sensor directly in the tranny.
    The other two wires should be pins 3 & 4. As you can see, I've tried the other two wires across the harness but they didn't work at all.
    Sent from my Droid using Tapatalk
  20. #100
    08-15-2006
    Perth Amboy, NJ
    1,558
    http://vid165.photobucket.com/albums...414_153550.mp4
    http://vid165.photobucket.com/albums...414_154757.mp4
    Couldn't read the speed in the 2nd video, computer battery died.
