Thread: Went to wire up the speedo...
Page 7 of 10 FirstFirst ... 345678910 LastLast
Showing results 121 to 140 of 195
  1. #121
    08-15-2006
    Perth Amboy, NJ
    1,558
    so it works? but only when the tank is half full and below?
    ok so the signal er voltage reading is the same... hmm. Wait, has anybody tried connecting the power wire for the sensor to just a 12 volt source, like the cig lighter power? If Galante is having the signal, then he found the right signal wire, and its getting to the cluster, so what if he just tapped into say another signal wire for something else, maybe something with the fuel gauge? Dang I need to get a new speed sensor so I could try this!
    This is what I'm wondering as well. I'm thinking the voltage goes up as the fuel tank goes down. After a while, the speedo works perfectly. If we use a 12v source for power its constant, then in theory it should work.
    Sent from my Droid using Tapatalk
    run1206's Rear Disc Tutorial
  2. #122
    10-18-2007
    Glen Burnie, MD
    1,314
    Im so lazy, Im contributing nothing to my own thread. Damn 60+ hour a week job :(
  3. #123
    ^its cool bro, your not the only one with tht problem haha.
  4. #124
    Quote Originally Posted by run1206 View Post
    Jus curious if anybody has had time to give this a try
  5. #125
    since im in the 5 speed club im gonna look into this this weekend also. I do however need to get a harness to fit in my speedo since im an 02. Y dont one of you take a reading and find out the voltages with your speedo working then fill her up and take the voltage again? Has any one tried the constant power to the sensor?? I am not sure but i wouldnt think its a 12v i would think more like a 5volt from the ecu ??
  6. #126
    08-04-2003
    NY
    4,344
    I would think its +5 volt as well and depending on how fast the gear spins will determine the amount of resistance created, then the ECU will measure the voltage drop and translate that into speed.
    99' Galant ES
    4G64/63T
    AEM EMS
  7. #127
    Ok question - looks like speedo gear = VSS?? if so the service manual states 0 to 8-12v and its done by pulses not a set voltage apparently... This is pin 3 on c-17 which is already known. I dont see any reason to use pin 4? Acording to what i see - pins from the speedo gear 1 goes to 12v battery, 2 goes to ground (middle pin) 3 produces pulses i would guess?? Pin 3 is connected to pin 1 with a resistor in order to test the operation of the speedo gear and produces pulses...
  8. #128
    ^ yep pulses, which would then turn into a digital signal in the ecu, and then sent to the speedo. i think... idk anymore lol
  9. #129
    i dont think that the ecu sends the signal to the gauge i think it goes to the gauge as well as the ecu and both get the same signal from the wiring...
  10. #130
    that would make sense but in this diagram, it shows that the radio cluster and cruise come out of pin 80 on the pcm on one wire. TO me that would be digital, because I haven't had a problem with my radio sense I did the 5 speed swap.
  11. #131
    Speedo working 100%
    Uploaded with ImageShack.us
  12. #132
    08-15-2006
    Perth Amboy, NJ
    1,558
    Excellent! Any specific way you wired the connections?
  13. #133
    Pin 3 aka yellow/black goes to yellow black on that harness c17. On the harness there is a big red wire that provides ignition 12v its the only fat red wire on the harness - use that for 12 and connect to pin 1 on the speedo which is black blue. Pin 2 is grnd anywhere should be fine. Thats it works like the auto speedo.
  14. #134
    YES!! hahaha! now i just need a new speed sensor...
  15. #135
    08-15-2006
    Perth Amboy, NJ
    1,558
    Quote Originally Posted by Johnathansgalant View Post
    Nice!! I'll do the fix on my car tomorrow!
  16. #136
    i knew you would figure it out john.
  17. #137
    haha i wish i could take the credit i just get lucky a lot and my car still starts..
  18. #138
    10-18-2007
    Glen Burnie, MD
    1,314
    Sweeeeeeeetttttt thanks dude!!!!
    EVO 4G
  19. #139
    12-02-2008
    Carteret & Manalapan, NJ
    1,263
    woooooohoooooo!!!!! Hell F'n yes bro nice job!!!
  20. #140
    12-02-2008
    1,263
    Hey you dont mind if we get some pix...Im a visual learner.lol Just to get an idea how everything should look.lol
